lookin for input on a cam
I recently picked up a 2000 trans am.its a m6 with a lid,smooth bellow,3.73 gears,mac mid length headers,borla catback.ran a best of 12.9 with a 2.1 or 2.2 60 foot.the guy i got it from says its never been sprayed but the bolts in the hatch,switch in the ashtray, and maf translator tell me different.im lookin to get into the tens cam only with spray.would prefer to keep the shot on the smaller side.i have been lookin into the trex cam and ms4 but have been told from a buddy to ask pat g about a custom grind.not lookin to spend alot but also not trying to cheap out as i plan on goin with a lq4 built for boost once the car is payed off.
Here's a link for you to check out.......
https://ls1tech.com/forums/dynamomet...rs-inside.html
So switch to long tubes?the cars got lca's, sfc's,adj torque arm and panhard rod.I checked out the polluter cam,considering goin with v1 because with the v2 there is a chance you have to flycut the pistons.
I would suggest if you are doing a cam to get some 243/799 heads while you are at it, they can be had for fairly cheap these days. You are going to have shitty driveability with enough of a cam to run 10's w/o doing heads.
Its got an aftermarket diff and girdle but i have been putting money aside because it is still a 10 bolt.I may look into heads because i do daily drive this car.
