Air Conditioner is driving me crazy!
The AC works decent I guess, except I am embarassed to use it. Heres why:
http://www.fbody.com/members/Thunder...800ACNoise.mp3
Anyone have a clue. The noise occurs when putting Turning the AC on, not the fan. I posted it somewhere a while back, and still havent fixed it. I found the clip, and what the heck maybe someone knows. Summer is creeping up and I cant keep hiding from my AC. The windows down wont cut it in Texas. Thanks.
John
John
Originally Posted by Z28Venom
Oh man.. that sounds nasty.. I hope you get this one figured out..
It is a grinding, but a hollow sounding grind/snawl/growl. Pressure leak. Where to look? Thanks ramairstyle00.
Originally Posted by 2KThunder
The clip is in the Engine Bay. I have heard AC clutch. is the clutch replacable by it self? Thanks,
John
John
Originally Posted by fullfloatingHD
The clutch itself is replaceable sometimes in car, however I normally choose to take them out. Of course like every other AC problem car on LS1 tech i'm gonna say take your car to a professional, it will save you money in the long run. Their are quite a few things DIY guys don't consider when doing a AC repair, that could ultimatly ruin the compressor totally let in plenty of non condensables and don't vacuum at all or not properly resulting in blockages and a soaked desicant.
mine makes the EXACT same noise. i forgot that i had the A/C on, revved thru first till about 6k and it was toast. im hoping its just the clutch, but i dont know. mine has since stopped blowing cold so im starting to lean more toward a completly F#$&ED compressor. how much have you used it since it started making the noise? mine blew cold w/ that noise for a while but doesnt now.
Dan
i did the same **** to my 98, hauled *** 125 mph down the freeway pretty soon my ac took a dump the thing froze and the belt about caught fire when it shredded, i replaced the compressor the orfice and drier,
good luck
J
good luck
J
Mine does it too, did the same thing. These things don't like revin to 6k with the AC on, I always ride with the t-tops off now, even when it is close to 100 degrees and humid as hell. It sucks, just never had it looked at yet. I'll be checking back here to see if ya figure it out, let me know if you do.
Nick
Nick
A word of advice to everyone. Use your AC for about 10 minutes every couple of weeks so the seals can get lubricated. Premature compressor wear is almost always caused by someone not using there AC often enough. I really wish they'd put this in the car manuals because it really is a huge issue.
Originally Posted by z289899
What about when it is freezing cold out? Just let it sit in the driveway and run the A/C?
you can run the AC, and have it on full heat too, will work fine.
Ryan
