Piston Slap getting worse?
Hey all
So my LS1 has piston slap, usually it goes away once the engine warms up and I just continue on my merry way.
However recently, I've noticed that between 1000-1500 RPM, usually when the engine is decelerating, I get the same noise. Doesn't matter what temp the engine is at, sometimes occurs when I'm stepping on the gas as well.
Is this something worth being concerned about?
My 00 trans am with a magnaflow cat back has made that sound for quite a while. I have a tick at idle , which may or may not be the same sound. Same exact symptons as yours , decelleration,sometimes while gassing it, and 900 to 1400 or so rpm range. I never could figure out if the exhaust drowns it out or if it just stops past that. Strange thing I noticed about mine though , if I take it out of gear (m6)while coming to a stop it still does it. I stopped paying attention to it. It's done it for awhile and car runs strong. So until something else happens due to it ,I now ignore it. The idle tick I will fix, I got some solutions on here . But that , I don't pay it any mind unless it gives me a reason .
I'll bet its not even piston slap....that term is used for every freakin noise a LS1 has! Piston slap noise is barely noticeable! Its most likely carbon knock or a loose timing or dirty lifter or wrong worn out engine oil you are hearing etc. Also ya know the purge valve mounted on the intake manifold can make ALOT OF TAPPING NOISES.
Think about it how long do you think pistons would last if they were KNOCKING in the bores? Not very long, blue smoke would be pouring out the exhaust pipes!
Honest piston slap is that diesel type sound you hear at 1st start up, If you hear KNOCKING you have other problems.
The reason this stupid piston slap noise BS started is the dealers started blaming every engine noise on piston slap to get out of repairing the REAL troubles. Now EVERYONE says piston piston piston slap....geez H Christ
Example I took my 99 TA back to the dealer under warranty because the lifters were ticking badly......they tried to blame it on piston slap. Took it to another dealer they said bad lifters, took it to a 3rd dealer and they also tried to blame it on piston slap...IT WAS BAD LIFTERS...................
NEXT person posts up PISTON SLAP ......................
Hey all
Yeah I live in the northwest, so summers are pretty hit and miss here, could be 80+ everyday, or 60 lol.
I only thought it was piston slap because it's the same noise the car makes when I first start her up, then goes away after a couple of minutes. I'll take a video sometime
