2002 issues
I do not have any ses lights on at this time but i can obiviously get my hands on a maf clearner i also picked up some kn filter cleaner and just got my oik xhanged again 1k miles before it was due just to make sure yano. But i will start with a maf cleaner and yeah i do probably need a tune up plugs n wires. Im surw theyve never been changed
Also im having issues with the car over heating on hot days and in traffic in hot days 50/50 anti freeze is always at the right point of the dip stick no leaks was told to take out the windshield washer resivior and maybe one or two other pieces of plastic or sonething to try to get more air flow to the radiator though
if the plugs are old, may as well replace them. I'd srart there...
And no 2002 Z28 came with a single fan. They were all dual, same as every other LS1 F-body from '98-'02. If you have a single fan currently, then this is not stock and there is no telling what other sort of modifications may have been made to the cooling system or air routing/fan shroud. Did the car once have a Procharger on it? A slim line single fan conversion is common to make space for a centrifugal blower. Or perhaps the stock fan motors died and someone just swapped to a single fan, but again there are several areas of this conversion that might be suspect depending on why and how it was converted.
Is the single fan due to the fact that one factory fan is missing or because they were both removed and replaced with a single, larger diameter fan? Whichever the case, this is not stock and may have something to do with your cooling issues.
Here is the thread I mentioned above, if you want some in-depth reading on the topic:
https://ls1tech.com/forums/general-m...g-success.html
