Verifying engine condition
Id also like to hear input for verifying condition of a used 5.3.
The head gaskets can be re-usable ($32.00 for a pair of new ones) can you rationalize taking a $32.00 risk? The head bolts aren't re-usable, you'll have to purchase new ones regardless.
1. Remove the heads check for damage to the pistons and high cylinder wall wear.
2. Scotch Bright Pads & Brake clean is your friend if you find no damage.
3. Install new head gaskets (LS6) and head bolts.
And enjoy your engine!
Eddie
Eddie
I'm not an engineer by any means but I thought the purpose of Torque Yield bolts was to act like a spring with a targeted clamping force range as the heads and block expand thru heating and cooling cycles?
Not saying that reusing them isn't possible.... but it's cheap risk, worth not taking. Personally....I would just buy ARP head bolts and call it a day.
I even reuse my head gaskets on my aluminum block turbo engine. This is the 3rd time I've put the same head gaskets back onto my engine and pushed 20+ PSI every single day for months on end.
Is it the absolute best idea? No, but at some point you venture into the realm of overkill and extra money spent sees absolutely zero returns.
I'm just following recommendation set by GM Engineers on the fasteners, I'm not saying it's impossible to reuse the head bolts, but I would simplify things by just going the extra effort and buying for certain reusable (ARP Head Bolts) I don't like uncertainty or unneeded risks whether it's N/A or Pressurized HP.
But once again I see your point/position and its incredible that you're getting a lot of good usage of your head gaskets.
Eddie
Send an oil sample out to someone like blackstone , they will provide a report that will show the contents of foreign materials in your oil such as water , coolant , bearing soft metals etc... along with a reference to if these are just trace/normal levels or of concern.
Over the years it has been my personal experience to trust an engine last opened up by the general over anything you spend money on to open up or upgrade. You can have a lot of fun with bolt ons , convertors ,gears, suspension with your 5.3 don't open it up unless there is an issue with condition , then I would be parting out or selling off the 5.3 you have and go buy a known good one instead vs. opening the engine up in any way
Of course if your looking to make big power NA then you would have to change internal components to add compression , add strength , promote increase airflow (heads/cam)etc...
