lS1 Edit ?'s!! Pros and Cons
ok if sumone could explain exactly what LS1 Edit will do and the pros and cons of it, i know it like erases all your codes and could be bad.. but i dont know enough about it to determine if its good or bad or what..
It is software and a cable that allows you to reprogram your car's PCM. You can make an almost endless variety of changes. We have an entire forum here at LS1Tech devoted to "PCM Diagnostics and Tuning". Check it out.
Oh, and yes, it is good but HPTuners is much better, IMO.
Perhaps you didn't read above but we have an ENTIRE FORUM dedicated to this subject. It's called "PCM Diagnostics and Tuning."
But ok, I'll play...
WOT shift points (A4)
Part throttle upshift and downshift points (A4)
Timing advance
Converter lockup points (A4)
Fan settings
Toggle off certain diagnostic trouble codes (DTCs)
Adjust shift properties (A4)
Adjust fueling
Turn off TQ management
Adjust Rev limits
Change idle speed
And MANY MANY other things!
And yes, if you don't know what you're doing or are dumb about it you can hurt your engine and/or A4 transmission.
Timing advance
Fan settings
Adjust fueling
Adjust Rev limits
Change idle speed
Originally Posted by 99CamaroSS_
how much did it cost to do LS1 Edit?
You can purchase HP Tuners setup for 500.00 + 10.00 shipping @ www.hptuners.com and I would highly recommend this over LS1 Edit now. Like was was stated many times before, the PCM tuning section has this question and about 9,338 other threads about similar topics.
