Porting/polishing 243 heads worth it?
Hello everyone, I currently have an email in to TSP but I am impatient and bored at work, haha.
I have a 2004 CTS-V LS6 swapped in to my car. Engine is stock aside from the swap headers and a CAI. I am planning on a cam swap and while doing research came across the TSP cam/head packages. The car see's little to no street use, and it is a drift car so it see's extremely hard driving for sustained periods. I think the TSP Torquer V4 is the cam for me, but I am curious if there is any gain to be had from the Stage 2.5 headwork they offer? What kind of gains can be expected from that with an otherwise stock engine?
Thanks!
Thanks!
My hand ported 799s( same as 243) and cam, plus supporting mods picked up over 100 rwhp.
No reason why you couldn't do that with a decent head cam combo imo
P&P heads are an excellent choice. As Mike stated, there are large gains to be made from a well thought out heads/cam install. My 243's were sent to advanced induction for their 226 cnc program. The new heads netted me about 60+ RWHP. With the aftermarket cam I already had in, my total gains were comparable to Mikes. TSP is a great company and I'm sure they can take care of you. Just a suggestion, keep your options open and do your research. Maybe contact a few different head porters and get their opinion. They have years of experience to share. Good luck.
LS1Tech Administrator
Received 1,492 Likes
That is what I did. Went from 117 cam bolt ons to 122-123 traps after head swap with tune
Awesome, thanks for input. I am still waiting to hear back from TSP to place the order, but I think I've decided on the stage 2.5 heads, TSP .660 dual valvesprings, torquer V4 camshaft, and LS7 lifters and lifter trays. I also am thinking of having them mill .0065 from the head and using a .040 head gasket which (according to other posts on this forum) would get me an 11:1 compression ratio with safe piston/valve clearance.
100whp would be incredible. I am hoping for 400-425whp (I am at 5300'), Is there anything I am overlooking on this? Will the OEM injectors be ok?
An injector and fuel pump upgrade is a good idea. I went with 36lb flowmatched injectors and the racetronix fuel pump kit. For myself being NA at the moment, 36 do well with a HCI setup. You could also go 42lb for more headroom or if you decide to spray. I'm not totally sure what pump or injectors the ctsv has in it so I'm speaking purely from an f body standpoint
Sorry I misunderstood at first. I originally thought you had a ctsv. But it's just an ls6 swap into a bmw. You are correct thinking 28.8 on the injectors. Just to give you a baseline, I was at 440 RWHP with stock 28.8 injectors. Duty cycle was at about 96%. My 36lb injectors gave me the room that i needed and then some. As far as the bmw fuel pump, I would say try your best to find the specs and flow rates of that pump. Especially before you purchase other fuel delivery parts. Outside of that you should be good to go. I'm not sure how detailed your list was but heres a few things to consider.
ARP head bolts or studs
TRI-Union kit if you plan to use stock rockers
I ended up going with the PRC Stage 2.5 as well as machining .007 off the heads and stepping down to a .040 Cometic gasket for an 11:1 CR. I also did the TSP .660 dual valve springs, the TSP trunion retrofit, the TSP Torquer V4 camshaft, LS7 lifters and lifter trays, ARP head studs, and an ARP crankshaft bolt. Can't wait!
I drove the car all last season, here are a few pics.
The day we got the engine in
one of the first drives (went to the mountains to test the rear mounted cooling setup)
Some action
and how it sits today after hitting 2 different walls and a season of abuse
