Easy Question for Auto Cars...
I don't have the build sticker for my car, so I am not 100% sure which rearend is in it. It is a limited slip, for sure. The car is a 1998 Trans Am A4 with the 150mph speedo. At 72 mph in 4th, I am at about 2000 RPM (maybe just a hair over). I am thinking 3.23 gears. These cars also came with 2.73 gears, so help me figure out which I have.
Those of you who know what rearend is in your car, what speed are you traveling at 2,000 RPM in 4th? (Autos only.)
2000 at 72 sounds like 273's but it also depends on the rollout/tire height if your not on stock tires.
another way to verify what the car came with is to check the door tag with all the broadcast numbers gu2+ 273 gu5=323 but if the rear has been swapped all bets are off.
depending which posi style it has you can jack it up and spin it to see what the ratio is but only if both wheels turn when you turn one , just see how many times the wheels turn to make one driveshaft rotation and you have the ratio.
LS1Tech Administrator
Received 1,467 Likes
That's another way to tell, assuming nobody has changed the drive shaft.
71mph @2100rpm = 3.23s
Here's a good gear calculator site:
http://www.pszweb.com/car/gears.htm
It's actually the other way around (spin tire one full turn and count driveshaft rotations), but yes this method will work on a '98 since it would have the Auburn LSD (both wheels turn together.) The process is a bit different for an open rear or a Torsen style LSD - but neither of those would have come on a '98 V8 car.
Clarification on the 1st gear lock-out. Yes,it was an LT1 'thing' and as the OPs' vehicle is a LS1 Firebird,I should not have brought it up.
BUT,the 98 LS1 Z28 had it,discontinued with the 99 + later LS1 Z28s'.
Why GM had it for 98 LS1 Z28 and not the 98 LS1 Firebird I cannot begin to answer.
From the GM layout catalogs for Firebird and Camaro consoles.
From Firebird
97 LT1 GU2(2.73) #10297910
97 LT1 GU5(3.23) #10297909
98-99 LS1 all (both GU2 + GU5 #10279909
From Camaro
97 LT1 GU2 #10297908
97 LT1 GU5 #10297907
98 LS1 GU2 #10297908
98 LS1 GU5 #10297907
99 LS1 all #10279907
Puzzling !
From Firebird
From Camaro
Puzzling !
Hmmm, I have little reason to suspect that the previous owner would have changed driveshaft or rear ends. Mine definitely has a steel driveshaft, but matches the RPMs listed by RPM WS6 "71mph @2100rpm = 3.23s" I do not have any door or glovebox stickers, but I did not realize that I would be able to get a re-printout at a dealer. I may have to do just that.
I have seen some info in the stickies on how to ID the internals of the diff. Is there an easy way to ID the housing? Or are they the same? Actually, I have a pic of the inside from when I changed the axles. Does this help?
Housings are the same,carriers are different,there is only about 1/4" difference from the ring gear mounting surface to the center of the pinion gear between the two carriers,difficult to tell from the pic. Number of teeth(for both ring gear and pinion gear) would be stamped in both gears.
From Firebird
From Camaro
Puzzling !
From Firebird
From Camaro
Puzzling !
Thanks for your assistance. I will try the wheel turning method this weekend. The axle is hanging below the car, sitting on the wheels, and no driveshaft right now. Should I lift one side only? Both sides? Should I turn from the pinion input (if I can get enough leverage), or one of the wheels?
Also, in regards to the 1st gear lockout, yet another serendipitous photo I snapped just before yanking the entire console and driveline out of the car:
I am switching to a manual, so I'm trying to decide to stick with this rear end for a while, which I can do with 3.23s, as that is actually perfect for what I want, or if I have to swap out the 2.73s, which would be too tall for a T56 Magnum. Since it is a street car, I'll opt for the wider ratio T56, so that means I won't need a crazy short rear end to get off the line, and can still take long road trips with decent highway economy and noise. The car will have around 500 hp though, and the axle tubes have a fair amount of rust on them, so I am hoping I don't break anything. If it does though, then I am simply back to buying a new rear end. Before I do that though, I'd like to see if 3.23s are the right choice for my setup by driving around this way for a bit. I also have to change the pinion seal and probably do the bearings too while I am in there, as I discovered that it is leaking.
You'd want to have both tires off the ground, and turn them one full revolution (assuming both tires turn together in the same direction - which they should if you still have the original '98 Auburn rear) while counting turns of the driveshaft. This will be harder without a driveshaft to mark. If it's 3-1/4 turns, then you know it's 3.23s.
Any suggestions on what/where to look for a new assembly? The car will have ~500 hp, but will not be drag raced, so I assume I don't need to go bigger than stock. (Car will be a daily and a canyon carver.)
I would like to keep all of the brake lines (might actually have to replace, as some are pretty rusty at the junctions), parking brake hardware, 4-channel traction control sensors, as I am assuming most of this hardware is not included with a new axle. If I can get it custom narrowed by 0.75"/side, then I will be able to widen the rear wheels to 10.75" for 305 tires (unfortunately there are no 315 tires in the right 19" size).
Ironically, the gears are in good shape, despite the mileage, and the rear end has new axle shafts and outer bearings/seals. It is the housing and axle tubes that have rust and grit that I would like to get rid of. How much should I expect to pay for a full rear end with gears?
Sorry for all of the questions, but will I need an adjustable torque arm or control arms to set pinion angle? This will be mated to a Magnum T56 with an F-body tailshaft, so I will already have to get a custom driveshaft due to the change in trans length.
