Track ?
I did not, as of then, remove my AIR, EGR, washer fluid, or front sway bar. I plan to remove those and go back to practice and lower my times some more.
Yea i have the jack and spare removed.... did u happen to dyno before the longtubes.... that will be my next mod Longtubes and xpipe...
but thanks for the info...
I think your mph is way low. I wonder if there is something else going on.. Perhaps strong headwind?
You are starting off good then seem to maybe getting stonewalled or something to have such a low mph. I would expect 5mph more..
are you stalling up or flashing your stall? there shouldnt be any spin whatso ever with your setup. are you getting any shudders or wheel hop?
does it bog at all?
take us through one of your runs in detail.. if you have the timeslip list out the times.. Stock gears?
does it bog at all?
60ft 1.830
330 5.397
1/8 8.374
mph 83.02
1000 n/a
1/4 13.133@ 103.06
its liking the flash. dead hooks. on the stall it does about the same as flash but the flash has a better ET.
60ft 1.830
330 5.397
1/8 8.374
mph 83.02
1000 n/a
1/4 13.133@ 103.06
Your MPH there is really low for that speed. I am with ya. .I think that maybe your tracks MPH is off by a bit.
When I had an auto I prefered to flash it.. Car felt to respond better to that.
Here are my LS1 times:
Mine-------- yours
60' - 2.104 --------1.83
330 - 5.693-------- 5.397
1/8 - 8.601-------- 8.374
MPH - 85.25-------- 83.02
1000 - 11.085-------- n/a
1/4 - 13.174-------- 13.133
MPH - 108.00--------103.06
Here my guess shows you should of been at least at a 12.8 since at the 1/8th you were .226 ahead..
Mine-------- yours
ur making 20 more HP, and im guessing ur a M6 car... which would explain the MPH...
hmmm.. I had an auto LT1 with 3.73s and few bolt ons doing 105/106 with less power than you..
I dont think the power is it.
How does your power look on a dyno graph? is it clean or jerky? Maybe your car is shifting too early or late?
dont wanna buy another set right now... these were a freebie, and once the longtubes and x are on and the cam and valve train in a month or so... should be a good combo.... im sure it is a little to much tire... bogs a tiny bit after it hooks.... ill most likey be doin a bigger stall soon anyway.. 4400 TCI i believe
im also having my pcm done tomorrow. so hopefully it will help some.. ill have dyno charts and track results as long as it doesnt rain tomorrow... thanks for the info Guys!!!!
