PCV Help
So run the drivers side valve cover with a ported baffle instead of a PCV to manifold vacuum, and the passengers side to the intake system IN FRONT of the throttle body, but AFTER the Maf.
If you run it any other way it can mess with the MAP sensor values and/or have oil consumption issues
On the driver side valve cover where the stock PCV valve connects and routes to its connection point on the intake manifold looks like a good point to install a catch can. It seems installing a catch can in that circuit between the PCV valve and where it connects to the intake manifold would capture the blow-by contaminants, some water vapor and other stuff before it had an opportunity to reenter the intake stream.
Anyway, that seems like the best solution to allow the engine to breath using fresh filtered air, still retain the stock PCV setup while installing a catch can to capture the blow-by contaminants.
The valley cover port was a replacement ( for a time ) for common "oil in intake" issues early LS1's had when they utilized a true PCV valve. The best fix imo is to use the orfice pcv or the 05+ drivers side valve cover and run that direct to manifold vacuum without catch can at first ( not needed if the engine is sound and you are naturally aspirated )
the clean side is to allow intake of vac to relieve any possible seal problems so it is plumbed into ported vacuum in the TB or usually into a fitting in the air intake tube as mentioned earlier before the throttle body, but after the maf. This keeps the map sensor values from possibly going wonky.
The valley cover was used to completely replace any vac port on the drivers side rocker cover so if you want to use that? Plumb directly to manifold vacuum and plug the drivers side pcv port completely.
Newer systems all use the orfice style in lieu of a true PCV because it works, and prevents much oil problems. The newer valve covers also have a better baffle for oil splashing and drainage.
I will be running the stock valve covers that were on the 2007 donor engine. I'm saving this thread and will try the Holley VC's if the stock units do not work properly. Thanks for your advice.
