Power windows. Need help
LS1Tech Administrator
Received 1,793 Likes
The BCM needs repair or replacement. Here is a thread on the matter:
https://ls1tech.com/forums/general-m...blems-fix.html
Resolder BCM
As RPM stated this is covered in another thread. It's super common and an easy fix, IF you know how to solder. The BCM (Body Control Module) is under the passenger side glove compartment. Search YouTube for ( Camaro BCM 2002) this and you can find a video outlining the process. I recently did this on my 02' Z28 and was successful. It was easy for me as I have been soldering boards for years. If your not good at soldering then learn that first.
Good Luck,
Stingerrray
Good Luck,
Stingerrray
