Need help with cooling issues
It's true that, without fan adjustments, the 160° T-stat won't do anything to lower coolant temps when you're sitting at idle or creeping along at lower speeds. But at steady cruise, and/or in cool weather, you'll still have a reduction in running temps even without fan tuning. Keep in mind though, that the stock temp gauge on the '99-'02 cars won't show much movement for temp fluctuations within the 185°F to 235°F range (you'd need a scanner to verify true coolant temp).
Going back to a stock 187°F (86°C) t-stat will NOT fix this problem though, unless the problem happens to be that you have a faulty 160° T-stat that's sticking, or you happen to burp the air out of the system while swapping T-stats again.
