help
Old Sep 5, 2018 | 12:39 AM
aleks's Avatar
Default help
my 2002 camaro ss temperature sits at 210 all the time might move a little to the right but still in the middle is that normal and also sometimes after a long drive after i park it and go back to getting it ready to start the gage makes 230ish but goes down as soon as i start it up
Old Sep 5, 2018 | 10:01 AM
Normal....
Old Sep 5, 2018 | 12:02 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The temp gauge on all the '99+ LS1 F-bodies will show a hair under or over "210" for any actual temp in the range of ~185°F to ~235°F - so that is normal. The temporary spike you see immediately after a restart sound like normal heat soak that will occur in certain situations.
Old Sep 5, 2018 | 03:37 PM
SouthernRex's Avatar
210F is right around where it should be. Mine hovers in my 1998... like RPM said, 180ish to 220ish after driving for 10 minutes. I've always thought of 210F all my life as "operating temperature" (although, I guess it's actually lower than this.)
Old Sep 5, 2018 | 03:51 PM
01WS6BLACKLS1's Avatar
Agree with above guys. Throw in a 160 stat, and have the fans tuned to come on at lower temp. That's what I did. Never have an issue, other than my gauge still at 210. But I know its probably due to how the engine compartment is compact and tight.
Old Sep 5, 2018 | 04:38 PM
aleks's Avatar
Thank you all I’m new to the Ls world. Coming from a 2003 Mach 1
Old Sep 5, 2018 | 04:40 PM
HCI2000SS's Avatar
Mine does the same thing. I thought the 160 stat would make it read lower but it appears not
Old Sep 5, 2018 | 05:01 PM
RPM WS6's Avatar
'98s are a bit different, their temp gauge has better functionality. If you were to lower your fan settings, even without changing the t-stat to a lower temp (stock is 187°F), you'd notice that it would hover just above or below the second mark rather than the third ("210") mark on the gauge.
Old Sep 5, 2018 | 05:14 PM
That's probably not the worst idea, seeing as I currently live in Florida. I've just never bothered because I figured it was right where it should be without overheating. I'm guessing this is something I can ask Frost to do when I do mail-order? (I'm just bolt-ons, nothing internal has changed.)
Old Sep 5, 2018 | 05:52 PM
RPM WS6's Avatar
This is a pretty basic thing to change, so addressing it via mail order tuning should be no problem at all. The stock fan settings are:
Low speed on/off @ 227°F/218°F
High speed on/off @235°F/228°F
...so there is room for improvement even with the stock t-stat.
Old Sep 14, 2018 | 06:56 AM
LS1 pwrd NOVA's Avatar
Flush your coolant system, after I did that it hovers a little under the 210 mark now.
Once you flush your system good, it should be more efficient as long as your radiator is in good shape.
Its also a good thing to maintain in these cars with a good flush
Old Sep 14, 2018 | 03:08 PM
For some reason he has multiple threads about this, but don't forget to make sure there's no air bubbles.
