Lq9 first build
Lq9 first build
So, i am starting my first ls build and have aquired an lq9 dropout from a denali yukon xl. I am wanting to build something around the 700-800hp range. This will be going in a roller and most likely be a strip car only. Id like any newb advice or help that i can get. Ive stripped it down to the short block and plan to pull the pistons, cam, and crank tomorrow. I was thinking from the little research ive done of stock crank, big roller cam(not sure of numbers), forged rods and pistons, strengthened pushrods with a trunion kit in the rockers fast 102mm intake and tb(or something cheaper with the same flow ls2 or ls6 maybe?). Any help or hints would be much appreciated!
I'd call ws6store or TSP and have them give you a bulk deal on everything you need to put it together. Then find a good used huron turbo kit. For fuel I'd go with chrs1313 dual pumps and go with a th400. Then get the appropriate drive shaft and cross member that will work with either a 9" or dana S60 rear.
Anyone have a parts list or something to go off of?? Like the item numbers on the felpro stuff and arp etc.... also what all can i keep stock so i can start washing parts.
Restricted User
A stock LQ9 will hold 700 at the crank reliably, without anything ARP.
I'd probably do a mild cam and valve springs, some fresh lifters, head gaskets.
No need for a big throttle body or intake manifold with boost. Use what you think looks good or is cheap.
Im looking for more around 800+ at the wheels
