Crank Bolt Problem
Crank Bolt Problem
Hey guys so I’m putting on the harmonic balancer and I was tightening it down with an old crank bolt. After tightening it for a while I thought it was on good and I tried to loosen the bolt. However when I try to loosen it it does not want to loosen at all and has a lot of torque on it. I don’t want to break the bolt and screw it up. What should I do?
Have power tools?
I've found that sometimes it just needs the initial hit from an impact to break it free.
Auto or manual?
Just put a 3/4" drive breaker bar with a socket and take a hammer and give it a good wack counterclockwise.
Yeah i wouldn't recommend using the bolt to seat the balancer . You should have used threaded rod with nuts and washers and made sure the rod was threaded all that way in before pressing the balancer onto the crank.
Yea I feel like a complete idiot for doing that, I was going off of LS1howto and that’s how they did it. You live and you learn I guess 🤷🏼dum♂️
I'm going to get flamed for this. But a few times I've put the balencer in the freezer for an hour. Then cut the shank of bolt. Then lube it up a little and put air hammer on bolt head and drive it in. Takes very little effort. (But now I have the correct install tool)
I’ve heard of people heating the balancer but not freezing it
Well that was before I got ls1tech educated!!!
