Need help!
Old Feb 22, 2023 | 08:18 AM
1Slowstepside's Avatar
Default Need help!
hey so i’m new to this forum, i ended up building my first engine, from an old 03 5.3 i bought because my old one blew in my 2000 silverado, i did everything as i should (or atleast i hope i did) but i started her, ended up swapping the cam while i was at it, it’s a texas speed stage 3 cam along with ls7 lifters, the springs and the pushrods, ended up getting it tuned from a guy, but the truck idles high and is accelerating on its own, and wants to stall when i put it in reverse, won’t go over 30 mph but will rev up on its own, not sure what it could be i’m beginning to lose my mind PLEASE HELP!
Old Feb 22, 2023 | 08:27 AM
Default Need help!!
Old Feb 22, 2023 | 08:42 AM
kinglt-1's Avatar
Could be several things... Need to log data and send to your tuner. Could be vacuum leak, fuel delivery issue, tune needs work...etc
Old Feb 22, 2023 | 08:49 AM
the thing is the tuner did tell me the tune is set for a stage 2 cam, and when i texted him about coming to check it out he kept looking for excuses, i’m currently thinking it needs idle relearn, i’m pretty new to this, so i honestly don’t know how to check for a vacuum leak, and most definitely don’t know anything about tuning, but thanks!
Old Feb 22, 2023 | 08:52 AM
is there any way i can send you a clip of it driving? see what you think could be issue?
Old Feb 22, 2023 | 01:04 PM
ALL ULL C's Avatar
Texas Speed has 5 versions of what you say is a Stage 3 cam, which one do you have?
There a couple ways to test for vacuum leaks:
Smoke test which requires you to take it to a shop and will cost time/money.
Purchase a vacuum gauge from your local auto parts store to verify vacuum (never a bad idea to have tools for the future).
Or the tried and true spray WD-40 around the back side of the TB, vacuum hose connections, and then around where the intake manifold meets the heads.
Any service engine soon lights flashing or present?
I assume this is a cable operated throttle body? With the vehicle off ensure the throttle is returning correctly and then repeat when running (while in park). Just a couple quick snaps of the throttle and maybe even hold it at a low steady RPM and then let off to see what it does.
Start checking all wires/connectors up to the throttle body (IAC/TPS) to make sure good and secure.
I'd guess still has a MAF? Installed correct direction for airflow? Wiring/connectors all good secure?
TrendSetter's Avatar
find someone that actually knows how to tune and have them fix it. also that cam is probably too big. i have no idea what the numbesr are but in the world of stupid *** cam names, stage 3 tends to imply its fairly large compared to stock.
Old Feb 22, 2023 | 01:13 PM
ramairetransam's Avatar
you need a tune , also did you do a larger stall with that stage 3 cam ?
Old Feb 22, 2023 | 02:56 PM
its a stage 3 low lift cam 216/220, and for the vacuum leak i’ll try the WD-40 first, and there is a service engine soon that’s constantly on, and yes it is a DBC, im also about to check the idle because it might need a idle relearn, and yes MAF is installed along with all other connectors
Old Feb 22, 2023 | 02:57 PM
yes i’m running a 3k stall, which is what was recommended for the cam
