Help
. It also cost like $500 , i dont want to go to all that trouble with the few mods i have. I need a stall b4 i get a tune.Anyone have any ideas of anything else that could be wrong b4 i go to all the trouble of getting tune and having to get another in like 6 months.
I just want to make sure i need a tune 1st. I mean i am running .3-.4 tenths slower than i was before. Can me running very lean effect my times this much??? They way i see it i should run like .3 tenths faster w/ headers so i would have to pick up .6 tenths total. That takes a lot of hp.
Would the timing tricker work? maft? diablo?
Is it idling rough? Have you changed spark plugs? Checked to make sure all the plug wires are on the spark plugs?
I wouldnt mind really getting a tune except i have to drive to texas! I really dont have the time or that would be ok too.
Im confused about the rich or lean part. I have seen rich and lean and the computer things lean so it makes ur rich and bla bla.
As for the popping sound for Redlinels1, when does the popping sound happen. Have you had the hood open and can you pinpoint the area where it's coming from? It could be a leak at the header flange. Thats definitely not a good thing. I'm not sure if that will affect performance to to a degree where you are losing lots of time at the track.
How did you go about tightening the header bolts? Did you torque them down with a torque wrench?
I am sure it was the o2s because i had az scanned.
I didnt torque them down with a torqure wrech but i did get them tight. I dont hear any leaks and i run some water over them when the engine was just cranked ( it was cool , so i didnt break anything i hope) and i had no bubbles anywhere.
I expected to have to get a tune for maximum performance but i expected to run at least a tenth faster and never ever imagined slowing down .3+ tenths.
Thanks for the help.
What about over torqing them? If i dont have any leaks it couldnt effect anyting else could it?
My car is actually running good now. I suppose the pcm just finally adjusted itself. Last night I ran a 12.85@110.8
I also let someone who new a lot about headers listen for leaks and he said i had several on the passenger side. I havent retorqued those yet but i have the drivers side which i dont have any leaks on. so im hoping once i retorque that side ill be running a bit stronger.
I only got a 2.03 60' so i think i can improve that time a little also w/o a tuning.
. Damnit.
