My Dash Cracked!
My Dash Cracked!
How can this happen? It goes from the defrost vent under the windshield and goes left a bit to the plastic part above/around the gauges. How much is it to fix/replace this?
You always need to make sure that you keep the dash, or other plastics that are always exposed to the sun very moist. Meaning "armour-all" it. I would do this everytime you wash your car or once every 2 weeks.
The sun is killer on plastic
dont use actual amour-all though...if you ever quit using it, itll dry out the dash muuuch quicker and youll have more problems than you did before you used it
Mine is all cracked to hell as well, I'm just waiting til this fall/winter to replace it. Not real excited about spending any amount of time in the heat replacing that part. Should be able to find it off a wrecked car tho. However, that peice should not be painted to match, these plastic peices were molded in their respective colors, were they not?
