I think i may have a tranny problem
the guys in the tanny section wont answer so here it is:
My car when first purchased would second gear scratch under wot anytime of the day. Now it no longer does this. It shifts nicely, and there is no noise coming from the tranny, but It obviously doesnt shift into second under wot as it used to. Does anyone know what might be wrong? Are my clutches going bad? Has anyone had a similar experience?
If i should get a rebuild kit, what is a good one to get? Please help me if you can, I am like a father when it comes to my car, and I hate to see somethin wrong with my baby.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
When did you get it? Are you running the same tirs? How much tread have you worn off since then? Was it colder outside (you make more power in cold) when you got it?
it clunked hard once going into second, never happened again. Now it dosent shift as hard.
It always second gear scratched, cold, hot, asr off or on. I dont know if second gear scratching is normal for an a4, but I hope that nothing is wrong. I am beginning to think my second gear clutches are going bad.
I think i will just get a rebuild kit, and overhaul the tranny when i put a converter on it. that way I only have to remove the tranny once
Maybe it is getting second gear rubber but your tires are just worn.
If not try flushing tranny if that dosent work - put in a trans go shift kit. Your tranny is probably just getting worn and slipping a little. My tranny was taking about 2 seconds to shift from 2nd to 3rd, after my engine mods - trans go fixed it, at least for now.
