Sleeper mods?
i already plan on doing a E-cutout, but how much of a difference will headers make? and can you tell with the stock exhaust? what other mods are out there?
i already plan on gettin a lid and a ram air kit or should i get the FIPK?
thanks for all the help!
thru a stock exhast the headers wont make it too much louder but when you open the cut out
or you could do what all of us should have , and set up your suspention and drivetrain first.
in the last 6 months i have been getting seriouse about my set up .
moser 9" rear w/4.11 gears
nitrouse driveshaft w/ 1350 yoke
spohn drag rear sway bar
spohn LCA's
spohn TQ arm with duel DS loops
bmr pan hard
bmr SFC's
hind site being 20/20 i should have started with this stuff
Yup, I can see it now he'll crack that cut-out open when he gets a block away and be dippin into the throttle and pass his mom and blow her ears out and when he gets home they will ask "what is broken on your car?" LOL. But yes, LT's, cats and stock exahust will be pretty tame. After you go the lid and filter you can do what jaberwki suggested about upgrading the suspension/frame support(SFC's) i guess i'll save up get the rear-end first since it is one of the more xpensive parts, 9in with what, 3.42 or 3.73 gears? and i never got all the options that it comes with, like the posi and stuff and i have been meaning to read up all that
i plan on trying to see if i can fit a cut-out between the headers and cats, we'll see, from what i have read it is a tight fit!
thanks again!
and i decided, AS SOON as i hit Florida, the first things i buy will be a shift kit, TC, and Max Performance Summer Tires!!! And i am really lookin into the STS turbo kit for sometime in the future, but i am gettin WAY ahead of myself.
yet again jaberwaki and everyone else, you have been a great help!
I have a bit more done than is in my sig
but damn I wish I would have started with suspension too. I can hardly get any hook up now. (well not all squirly but definately too loose)HP + No Hook-ie = No Go-ie!
Smoke shows are nice...
but there is a time and place for everything. Free Mods
Lid
Cat-back (slp Dual/Dual if you have to be stealthy)/Cut-out
Nitrous
Drag radials
Torque converter/cooler
All that should have you solidly in the 11's (corrected maybe), and no one would ever know to look at it.
Lid w/filter of choice
Free mods
LCAs, SFCs get the tubes if you don't have ground effects. They tuck under the body so you can't see them unless you lay on the ground.
(do torque arm and PHR expences permitting otherwise not needed until big power)
TC
Cut-out (QTP)
Ported TB and MAF (despite arguments they work)
Bellows
Don't waist money on a rear or gears. A4s rarely break them and with a stall a gear does little.
All suspention should be black.
1.8 or better rockers work and no one will know.
Now with all this being done with a good tire, the right stall, a tune and good track conditions should net you a low 12 to high 11 and your victom will never see it comming.
-SSRA/FTRA ramair system
-lid (I don't think your parents will recognize it)
-headers (again, parents probably won't recognize it)
-stall convertor
Should be a pretty cool 12 sec sleeper setup.
