Car won't start?
i know what your problem is..lol..been living that for about six months. it is the vats system. ill tell you how to start it. ok, look when it cranks and it doesnt start just have the key in and the ignition running so that all your lights are on on the dashboard and wait about 3 minutes and then crank it up. it should fire up. dont start it before 3 minutes because if you do then it wont start and you are gonna have to wait another 3 min and so on. unfourtunately, you cant do much about this. another thing, from now on when you start your car just put the key in and turn it then wait for the security light to go off before you start it. i have noticed that when i put the key in and start it right away, i have alot more problems starting than if you do it like i said. the only choice to fix it is to take it to the dealer and they will charge u about 500 bucks to get it fixed or by a bypass module on ebay that is about 30 bucks. however, if you buy the module then your car doesnt have a security system and it can be easily stolen.
Is there a clicking sound at all like there is power going anywhere? If not it probably is the VATS, it is really simple to replace the tumbler and get a new key ground with the template supplied. The cost of the new tumbler from a parts store is about $45 and a key from the dealer could be $25, compare this to the $425 it will cost for the replacement from a dealer and it's a great deal. All the tools can be borrowed from the parts store as well. I had to do it on my 94 Z and my 00 SS already, not a prob. Good luck!
Haha pretty sure i got the answer to this one....I had the EXACT same problem about a month ago. Just filled gas, went someplace, came out to start and nothing. I had a crank and all that but could not here the fuel pump or anything. Had no fuel pressure at the front and the fuses and all that were fine. I bought a fuel pump, put it in the "access" panel way, and still had no luck. We tapped the old fuel pump to the battery just to see if it still worked and it did. Turns out it was a LOOSE GROUND WIRE TO THE FUEL PUMP! The mechanics said that it got knocked loose sometime so I wasn't getting anything. Was one of the most stressful times of my life and I wasted 350 bucks on a fuel pump when i didn't need to. Take it in and have them check for the loose wire. I am almost positive that is what it is, if not, try the fuel pump but I learned that you should always start small. If i would have done this, today I would have an extra 250 bucks (100 bucks for the mechanic to fix it for 2 hrs labor). Good luck and let me know what happened.
If it does nothing at all and the security light comes on this is the problem. This happend to me not to long ago. I cleaned the vats chip with alcohol and that cleared it up.
That's what she said...
i dont know if our cars have a fuelpump relay but my moms went out in her 96 chevy truck. you can put your finger on it and feel if it clicks on or not. its responsible for priming your fuel system with pressure (makes pump come on when you turn key on). if it doesnt click, get a new one. this could save you from having to buy a new pump and putting it in.
Originally Posted by 02blkragtopz
Thank you! This is the answer I was looking for. My wifes car (01 Deville) does this randomly. Turn the key and nothing but the securitylight justa flashin'. I called GM and told them of the problem (sugessting that it seemed to be security based) as it has almost left us stranded and it is still under warranty. GM's response: "We can't do anything unless we get a code". They wont even look for anything wrong. (Me---> <----GM Cadillac Division) BTW: I can pay to have them look for something, isn't that soooo nice of them.
