H/C or NX kit?? 12 bolt?? Opinions please..
Heres another newbie mod thread..Ive had a couple LS1 cars but this one will be the first Ive done anything too..
Car currently has the following..
TCI converter, Lid, Brian green ram air, Pacesetter LT's, P/P TB, Comp Cam, LS6 intake,3.73's..
Have vig 3200 converter,full rear suspension sitting here as well as Weld Prostars w/ ET streets..
Should I step up to a set of Stage 2.5 5.3 heads or just spray it to death..Have the hookup with NX through a buddy..
Car needs a better cam, looks like I can get a nice H/C package for around $2000, but the NX is around $500..I just cant see the H/C making enough power to make it worth the $$ difference..
Also considering dropping the cash to put a 12 bolt in it, opinions??
Someone please help..
12 bolt definatly...you will need it the first time you launch on those et streets...where are you finding a heads/cam package for $2000 because heads alone will cost you that...and that are cheap ones...cams another $300-$500 and unless you are doing it yourself installation is going to cost a lot too....nitrous is cheap power...but power nonetheless...i prefer my power there all the time...howver others may disagree...that is really your preference
Another vote for the 12 bolt here (or better yet 9") Build everything around to hold the power then build the power. That way you and your car are not broke at the same time.
Originally Posted by House347
I've heard the 9" rob's more power and is heavier, any truth to that? I need all the help I can get..
That's what she said...
Talking with TSP about the PRC Stage 2 -5.3 heads and Magicstick..Possibly a Futral Cam, there cam package is more,I think around 700..I was considering doing the heads/NX/12 bolt and leaving the cam thats in it but was told its not good for nitrous..224 221 .581 .566 113 LSA..
Originally Posted by TheBlurLS1
cam needs more exhaust duration than intake to work well with nitrous. when sprayed, your motor has more trouble getting **** out than in
