thinking about a firehawk
Old Dec 5, 2004 | 09:28 PM
bucklwi1's Avatar
Default thinking about a firehawk
I am considering trading my 2001 Z28 in on a 2002 firehawk. I was just wondering if people had any advice for me as to how I can tell if the car has been beaten on? I know it may be tough to tell, but wondered if there were any secrets.
I have a carfax on it and it looks clean, but I haven't physically seen the car yet. I have seen pictures but will see it up and close this week.
any thoughts?
Old Dec 5, 2004 | 09:35 PM
JMBLOWNWS6's Avatar
If the rear has been hit check the hatch aligment. Look for oil leaks under the car. Other than that should be sweet. Sounds like a nice car. You might want to look at the exhaust manifold bolts to see if it has been demoded.
Old Dec 5, 2004 | 09:45 PM
bucklwi1's Avatar
OK, i'll check both of those things.
I noticed that it has aluminum "race-style" gas, clutch, and brake pedals. could that be an indicator?
Old Dec 5, 2004 | 09:49 PM
2kta--89formula's Avatar
In reality, most all of our cars are "Beaten" on a regular basis in the sense of tire spinning, 1/4 mile bouts...high speed runs, etc... Check for service records and make sure that the car was properly taken care of from a maintenance stand point. I'd rather have a well maintained car that has been beaten on than a car that has been driven normally <if there is such a thing> but hasn't seen an oil change in 20K. miles. Aside from the obvious blow-by, water in oil, knocking, pinging and leaks I would definitely look into the service records.
Old Dec 5, 2004 | 09:57 PM
bucklwi1's Avatar
i will try that too, but it is at a dealership so they might not be with the car. The car was driven 17k miles the first year and 16.7k miles the second year. The car is also a 1 owner car. This would seem to indicate the car was a daily driver, wouldn't you think? probably a good sign. I guess I will just have to check body panel alignment, look for oil leaks, ask for service records, listen to the engine, check tire tread depth, etc. I will have to give it a thorough inspection when I see it in person.
Old Dec 6, 2004 | 01:15 PM
Tiger2o69's Avatar
Yeah take your time. I thought I did with my car but found several things that could have gotten it cheaper. Werent bad things but would have knocked off some money.
Old Dec 6, 2004 | 01:37 PM
demonspeed's Avatar
It's not mine! woo hoo!
http://www.firehawk.org
Old Dec 6, 2004 | 03:45 PM
badhoopty's Avatar
a little thing, but check for bent fender tabs or fender tabs that have been bent back.
one of the key selling points when i bought mine was mint fender tabs, then when i took it back to the same dealer for its first service... they bent the friggin fender tabs.
Old Dec 6, 2004 | 10:22 PM
Keenov's Avatar
They can be bent back with ease though, I wouldn't worry about them. If you do see the bent fender tabs, just tell them to take off some $$ and then bend them back when you take it home
