what is this?
Old Dec 23, 2004 | 12:27 AM
scifone's Avatar
Default what is this?
first off im a noob.... but on the drivers side valve cover on the end closest to the firewall there is this round rubber thing with a round piece of metal that looks like a washer on it. there is a bolt that goes through the washer and rubber thing and through the valve cover as well.... what is it and what does it do? i dont know if this matters but my car has had the egr and air pumps deleted. thanks and sorry for the dumb question. i discovered it when swapping pushrods.
Old Dec 23, 2004 | 10:33 AM
txhorns281's Avatar
is it on the top of the valve cover??? the only bolts i know of that have a rubber grommet surrounding them are the valve cover bolts themselves (4 of em evenly spaced over the surface of the valve cover) ON the driverside near the firewall there is a PCV line but it shouldn't have a bolt in it... It should have a black tube that goes behind the motor... Other than that I have no idea what yer talkin bout... Previous owner could have tapped into the valve cover to run a gauge but right now off the top of my head I have no idea what sort of info you would get by doing that...
Old Dec 23, 2004 | 01:16 PM
LiquidFire350's Avatar
pictures might help, im stumpped too
Old Dec 23, 2004 | 11:15 PM
scifone's Avatar
ok ill try to get some up... would it matter that both of your cars are a '00 and mine is a 98? because i know that my valve covers have like 9 or 10 bolts instead of four like yours and the coils on mine are individually mounted... there is no bracket that holds them all on. it looks like its supposed to be there because the valve cover lips up around the grommet washer and bolt. it looks like its supposed to be there...
Old Dec 23, 2004 | 11:25 PM
maybe, but seeing it would help me understand it better
Old Dec 23, 2004 | 11:48 PM
scifone's Avatar
ok so i just got ahold of a service manual... its called a crankcase vent valve grommet...
Old Dec 24, 2004 | 12:33 AM
oh ok,........ what, wait, why is there a bolt in it then??
Old Dec 24, 2004 | 01:02 AM
scifone's Avatar
i dunno... im really confused. anybody else have any ideas?
Old Dec 24, 2004 | 02:12 AM
demonspeed's Avatar
It's not mine! woo hoo!
Um, wait... the 98 has perimeter valve cover bolts. Also, your 98 won't have AIR. umm... man, I dont know what is going on. I am drunk. what a red.
Old Dec 24, 2004 | 05:29 AM
Keenov's Avatar
I am drunk.
That explains it
