Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firebird How to Change Serpentine Belt<br>Step by step instructions for do-it-yourself repairs.
Never replaced serpentine belt, help
My serpentine belt needs replacing, its pretty cracked, im guessing the stock tensioner pulley is spring loaded so is there any way to lock it in the "loose" posistion so i can replace the belt then put it back to the running posistion?
i forget what size it is but get a closed end wrench put it on and push away from the belt.... this lets the force of the belt allowing u to take it off... just check the digram to see the way it goes back on.
never done one of my car yet, but changed the alternator on my friends cavalier and to relieve tension, i put a 15mm boxed end wrench on the bolt of the pulley of the tensioner, and turned it clockwise, if you turn it counter-clockwise the bolt lossens and the pulley comes off of the tensioner, i know a cavalier is not a LS1 camaro but being that its GM i think they would use the same style design with a 15mm and clockwise turning
however, i just remembered this, on my cousins 84 corvette, the tensior was turned by using a breaker bar and putting the square peg into a square hole on the tensior, as i said before, i havent looked at mine so im not sure which design ours have
![Lightbulb](https://ls1tech.com/forums/images/icons/icon3.gif)
I have not replaced the serpentine belt on my LS1 engine yet but on my other GM engines I loosen the tension on the serpentine belt by turning the tensioner pulley clockwise. I'd guess the LS1 engine is the same: clockwise on the tensioner.
