Engine shuts off during fishtail/burnout
My friend owns a '99 Camaro z28 and during fish tails or 360's the engine decides to turn off during the spin.
The rpm is below the rev limiter and no weird noises or codes are shown. Engine just dies, restarts fine.. Not low on gas either.
What could be causing this?
infinate reasons.... need more input....
does the cars power shut off as well?(ie guadges lights ect...)
or does the car just sputter and die?
is there a smell of fuel¿
what have you checked so far?
Clogged fuel pump? The burnout could "suck the lines dry" causing the pressure to drop and the engine to die, then when you hit the key it primes the system again and starts fine. Easy to check/fix.
he has the ASR switch turned to the off position and a couple weeks ago had the fuel filter changed.
No gauges light up (no Check Engine light)
I'll ask him tomorrow about if the entire system powers off (radio/lights/etc)
i had that happen once, when pulling a 360 in a wet parking lot, after i let off the gas, about half way into the spin the car died as it came to a stop, im not sure why, but i figure it might have been due to it starting to roll backwards, or maybe it slowed down too much, but the converter didnt have time to unlock, i dunno. Oh, does he have an auto or manual? The power never went out on mine either, just engine died...
Oh, well. Never happened since!
Nathan
Nathan
How much fuel is in the tank when this happens? He could have a broken fuel tank baffle which lets gas flow away from the pickup when doing such manuvers <sp?>...just an idea though I havent seen the inside design of our tanks.
edit: oops just saw the not low on fuel
Originally Posted by natronathon
yeah, im guessing it has somethin to do with the tc
I also doubt the torque convertor would be locked anyways considering what type of driving is going on during a 360 in a parking lot ...? just a thought
Originally Posted by lilstephsls1
when doing a burnout with the TC on, it will shut the car off. I've done burnouts several times with the TC on by accident, and it always shuts off.
All TCS can do is 1) retard timing 2) reduce throttle angle and 3) apply rear brake pressure, in that order. It is no way tied to killing the engine. Not saying that isnt what is causeing his problem...plus if he is doing 360's then most likely he has TCS turned off anyways so it should be disabled.
CT Hotness
Originally Posted by '02 WS6
Your car dies and you have to re-start it when TCS kicks in? When I forget to turn it off, my car just bogs down around 1100 rpms but it never dies on me.
when i was fishtailing and eventually crashed it, the engine shut off on mine as well, my friends old blazer would die if he did a burnout and let off without going anywhere
i think it has somthing to do with the imediated stopping of the tires, which stops the rear gear which stops the...... ect, and eventually stops the motor
re-read the 1st sentence, theres a message why not to fishtail, although mine was unintential and caused by hydroplaneing
no i was reffering to the torque converter, and I think i would be locked up because of the rpm the engine is pulling when you floor an auto in a parking lot, once passed 3K rpms it should be locked from what i understand. Mine happened when i let of the gas when doing a 360 in a somewhat wet parking lot, and the car came to an abrupt stop. I think the Torque Converter didn't have time to unlock and the engine stalled, somewhat similar to what happens in the same case when driving a manual and the clutch isn't pushed in in time... Thats just my educated guess. The electronics didn't die in this case on my car, because i had the radio on, and it took me a second to realize the car had died. Also, I had TCS off, cause I had planned on doing the 360!
Nathan
Nathan
