Request Part Numbers
#286
Originally Posted by HotWhipT/A
Hey, I'm looking for the black plastic molding that goes around the whole back window.
Center window trim molding: part#10423879
LH side trim molding: part#16633463
RH side trim molding: part#16633462
#287
Thanks, but its not the inside trim. Its the molding on the outside. I believe my whole back glass needs to come out to replace that trim too. It does have separate corner peices I think. I don't know if its one part # for a whole kit or what. Their might actually be 4 pieces like a bottom, corners and top. Yea well that whole back window trim.
#288
Originally Posted by MM98
LH vent- part#17997683
RH vent- part#17997682
Part#17997681 is the correct # for the center vents.
Mike
Mike
#289
#292
Originally Posted by mattsls1
Water pump bolt???? thanks
There are 4 but I lost 1.
LS1 water pump bolt (98-02) (m8x1.25x82.6, 31.8 thd, 17 od, GM7114M mzf) (need 6) = 12551926
#294
What about this ac line? The first picture in the thread. Someone posted the ac delco # but I need the gm #. Thanks
https://ls1tech.com/forums/generation-iii-external-engine/505574-whats-c-line-called.html
#295
https://ls1tech.com/forums/showthread.php?t=505574
#297
