Newbie post: High mileage LS1. Long term and purchase questions
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hi, this is my first post.
I've found a 1998 Z28 6spd for $8000. It's a nice car, but has 100k miles.
I'm really only familiar with old BMWs (which, for the record, are very very reliable)
I figure the Small Block Chevy V8 has to be mechanically reliable, but what other things could go wrong with a 100k mile car like this?
What things should I be looking at before I purchase one?
if there's a FAQ on purchasing these, could someone point me in the right direction? I didn't see anything when I searched.
Thanks in advance
Thanks in advance
check oil changes, check oil pump, tires, electrical system, look in rear drivers quarter for a dent, if theres one, good chance the car was beaten. happened to mine after going to the track a few times.
Originally Posted by Chapel
a dent from what exactly?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
what he's saying is to look for what looks like a crease on the rear quarter panels, usually right above the middle of the wheel well. It's caused by the chassis flexing when someone launches hard with it alot, especially if they don't have sub-frame connectors installed.
Does the car flex there?
Is it something from drag racing?
"It's caused by the chassis flexing when someone launches hard with it alot"
aha. yeesh.
And there's a fix for this? (not that I plan on twisting the car on a launch...)
100,000 miles is fine. Your window motors, and little annoying things will break long before the engine, if it was well maintained. Its no rule but most cars with 100,000 miles on them cant be lemons, they made it to 100,000 miles! Make sure the trans and rear are seem 100% normal! Maybe even get a mechanic to check it out.
8K is alright for a M6 but shop around. You maybe able to find another with lower miles for the same price or less. However if you like something and think its worth it, then it prob is! If your concerned about breakdowns get a mechanic to check it out, its worth every penny........or bring soemone who owns a fbody with you!
I have a 98 6spd with 132,000 and the car is sound. Just noticed the first signs of clutch slippage so, that's going to have to be changed. And it is the original clutch. The engine has a pinging/tinging noice around 3k rpm, but I've noticed in the posts that LS1's with much less mileage have the same problem. So, that's not an issue. All else is great on the car.
