Cam and not lose any low end?
Just wonderin if it's possible to get a cam and not lose any low end power. I know that a cam moves the powerband up. I just love the sound of a cammed car. And the extra power won't hurt either.
Thx
Thx
I'd love to get 4:10's in ASAP, but rumor has it, our week rear's won't hold up.....Was thinkin just getting a 9 inch with 4:10'a already in.
I think you can go pretty big and not loose any low end. I have a Hotcam in my car 219/228 .525 112LSA and it stronger than stock down low by a good bit. Based on the fact that you are concerned with low end power I think a 224 cam would be right up your alley.
And yes, the 9" is the way to go.
The power gain typically more than makes up for any low rpm loss. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Gears will help quite a bit with drivabilty as well as performance.
Why are you worried about low rpm power loss??
Originally Posted by MM98
Might even look into the GM ASA cam (226/236 525/525 110lsa)... Supposed to pull really well down low & through the midrange.
-Mike
-Mike
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
with any baby cam...anything in the 224 duration range you are not going to lose any rpm power that you acually use...(unless of course you use 750-1000 rpms
) and of these cam can put you in the 385-400 rwhp range with full boltons while retaining complete street manners.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Thx
Thx
Its called buying a milder than stock cam. It will reduce PEAK power and probably PEAK torque but it will move it further down the rpms, giving the sense of more low down grunt.
THIS HOWEVER IS A COMPLETELY POINTLESS MODIFICATION
There is no way on increaseing bhp (n/a engine) and not moving the PEAK torqu up the revs.
Remember BHP is a calculation of PEAK torque and rpms, if you have to cars producing the SAME torque but one does it 500rpm higher then it will also have a higher PEAK BHP number too.
There are 3 ways of increasing engine BHP (once all the lost bhp from intake and exhaust has been recovered):
1. More revs, ie moving the power band up the rpms. This sometimes involves much higher rpms (race engines and 4 cylinder cars).
2. More capacity, the more fuel and air = a bigger bang = more bhp.
3. FI, this is probably a good compromise, as it can give big cc stlye grunt with the same high revving characteristics of a high lift camshaft.
Guest
Posts: n/a
Yes, it is possible, and do-able.
The cam in my sig was especially designed to ensure no low-end was lost, since the vehicle might be used for towing.
The results of my research into cams yielded the following traditional split numbers for cam durations that, when used, would result in an increase in overall power, while retaining all low-end from a 650 RPM idle:
5.3L LM7: 206/212
5.7L LS1: 208/214
6.0L LQ4/LQ9: 212/218
Hope this helps.
5.3L LM7: 206/212
5.7L LS1: 208/214
Hope this helps.
5.3L LM7: 206/212
5.7L LS1: 208/214
Hope this helps.
5.3L LM7: 206/212
5.7L LS1: 208/214
Hope this helps.
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
The 206/212 cam gives an increase right off idle. Couple that with the upper rpm power increase of the 1.85 rockers and the result is an increase of power all over. This is power that you'll feel everytime you touch the throttle.
If I want more top end power I'll get headers. This cam is not a 10 second cam, but it has got me some pretty decent track times for what it is. See my sig. Actually, for guys that are going to stick with the stock torque converter, this sized cam works well. I used to run 12.5s@110 with 1.85 60s with the stock TC.
Guest
Posts: n/a
Instead of doing both a cam and rockers, you can get extra lift built right into the cam itself....Comp's 206/212 is .515/.522 lift, whereas Cam Motion give you .550/.544, no need for rockers for extra lift.
Is it the SLP rockers that give you upper RPM power, or is it the extra lift that gives you upper RPM power? If it's the extra lift.....
Do yourself a favor and get a good clutch and a big cam, since your clutch will like to engage around 2k, you will never notice the 5hp loss at 1k rpm that everyone always freaks out over. Maybe even grab some 4,11's and you'll have the same if not more lowend than the ppl that have the small cams with stock gears.
