bogs at the begining of second gear
Old Feb 1, 2006 | 11:15 PM
98TwoToneSS's Avatar
Unhappy bogs at the begining of second gear
i have a problem when i hit second gear when racing. when i get on it in first and then shift to second the car bogs down for a second and then it will take off and i have no problems in any other gear. Does anyone have an idea what it could be?
Old Feb 1, 2006 | 11:51 PM
oohtwo WS6's Avatar
Are you hitting the rev limiter in 1st ? What rpm is it bogging at when you shift into 2nd ? I hit 1st to about 5200-5400 rpm shift into 2nd and the rpms are at 4k right away....is it bogging at those rpms?
Old Feb 2, 2006 | 01:53 AM
andypdbz's Avatar
shifting at 5200-5400?
damn that seems kinda low, i usually shift at 6000.
but im not sure what the problem is, sorry
Old Feb 2, 2006 | 02:29 AM
jaberwaki's Avatar
question one.
M6 or A4?
second.
what rear gear?
third.
what rpm does shift happen?
Old Feb 2, 2006 | 02:37 PM
I shift at like 6300 to 6400rpms and it has stock gears and trans
Old Feb 2, 2006 | 02:39 PM
andypdbz's Avatar
thats funny since the rev limiter is set at 6200.....
Old Feb 2, 2006 | 04:39 PM
jimmyblue's Avatar
Moderator
I would suspect you are stepping into knock retard
and/or perhaps a badly tuned low speed mixture, and
either have to wait for the KR pullback to fade or the
short trims to bring your mixture around. All of this wants
logging, to see. Speculation is pretty pointless.
Old Feb 2, 2006 | 11:51 PM
jaberwaki's Avatar
you had your rev limiter upped?
there are 3 differant "stock" rear gears which do you have?
there are 2 "stock" trannys, which do you have?
Old Feb 3, 2006 | 02:29 AM
U think its funny right. Its not funny when my car pulls up to 6600 rpms and yours only pulls to 6000. The reason i raised the rev limiter to 6600 is because thats what it will pull up to with the cam . i have a 226/226 with a 584 lift and a 1.11 lobe seperation.I also put comp 918 springs, thunder racing hardened pushrods, and titanium locks and retainers.
Old Feb 3, 2006 | 10:03 PM
jaberwaki's Avatar
uh..... ok....
I was trying to help you , not make fun of you....
I asked questions that would help me isolate your trouble... if you wanna measure ***** size instead of fix your trouble then whatever...
you did not answer the questions....
if you do then i might be able to help, if you just want to argue.... i let my car do that for me
Old Feb 4, 2006 | 03:42 AM
not u man the other guy who replied is who i was directing it towards.
Old Feb 4, 2006 | 04:38 AM
jaberwaki's Avatar
ok....
might wanna hit the quote button next time, helps clear confusion like this...
Old Feb 6, 2006 | 04:42 PM
i have a m6 with 342 gears.
Old Feb 6, 2006 | 04:59 PM
'Trust''s Avatar
You may really want to consider ARP rod-bolts or equivilent if your spinning it that high, especially on a 98 which are known for weak rodbolts, there was a guy here shifting at 6600 and his rodbolts let go and shot the piston thru the block. Its a very good safety measure and $70 to save a few thousand on a new engine is a good deal. Just lookin' out for ya man.
Old Feb 6, 2006 | 10:30 PM
thanks for the info....
Old Feb 7, 2006 | 01:58 AM
jaberwaki's Avatar
ok... that helps...
what injectors and fuel pump are you running....
sounds to me like you are running out of fuel up top...
just something to think about..
good luck
Old Feb 7, 2006 | 03:19 PM
there both stock but i think the injectors are 28 lbs and im not sure what kind of fuel pump it has i just bought the car right before christmas.
Old Feb 15, 2006 | 12:22 AM
jaberwaki's Avatar
i think i would definatly look at your fueling then if you believe both are stock..
keep us updated on your progress...
Old Feb 18, 2006 | 07:15 PM
thanks for the information.
