View Poll Results: Do you think the !FRA mod helped you?
Yes
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
71
70.30%
No
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
27
26.73%
Yes, I saw improved dyno numbers.
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
3
2.97%
Voters: 101. You may not vote on this poll
Free Ram Air... is It Worth It?
#42
totally agree, also depends if you have a camaro or a Ws6... the ws6 draws air from the hood more and the camaro draws more from the bottom
Originally Posted by mpe488
pros:
slightly better throttle response
small hp gain
it's free
cons:
dirty filter
heat soak
heat soak
heat soak
now I wouldn't mind cleaning the K&N filter alittle more often, but I hate heat soak. It's bad for the engine, and it's bad for power. I also live in Miami where I get some ofthe worst traffic ever during some of the hottest days ever. Couple that with heat soak all the time and my engine won't be lasting the 130,000 miles that I need it to.
small hp gain
it's free
cons:
dirty filter
heat soak
heat soak
heat soak
#43
ok i did the fra mod before i saw all the cons and now my water temp is over 200, never went above 200 until now. bad idea, dont do it. now i gotta figure out a way to put that plastic thats been trashed back in its place.
