New to the ls1 seen
Old 05-03-2006, 08:33 PM
fastfbody's Avatar
Smile New to the ls1 seen
hi.
i just picked up a 1998 ls1 z28 tuesday.witch i happen to find on this website.im kinda new to ls1 im use to dealing with my old L48 carb 350 and my L98 350 tpi.
soon i will be doing a dyno just to see what shes doing be for i start modding . really hopeing for 275hp and 305 ft.lbs at the wheels .
first modds im going to get.
long tubes ,3 inch y pipe ,slp loud mouth muffler put some better rockers on the heads and toss a mild cam in.
any advice and tips would be a great help. im not new to cars at all but ls1 v8s are not the same as good ol 350s it is its own motor to my understanding.
Old 05-03-2006, 08:37 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Hardened push rods, and new springs to go along with your valve train upgrades
Sounds like your first mods are pretty good start, but you also need a Lid * intake * and I'd stay away from SLP products, including the loudmouth. The LM2 is so loud, ad in LT's and ORY's, and it gets so ******* loud its annoying as hell. It ruins a lot of the fun of having the car, you can't hear your passengers, you cant do quick bursts of wot without everyone in the tri state area knowing what's up ect..
*cough*scene*cough*
Old 05-03-2006, 09:03 PM
fastfbody's Avatar
Default ..
yea i was thinking about the vaules maybe 2.04 or something with some better springs.i alreay got a after market air lid.
Old 05-03-2006, 09:12 PM
2K2WS6TA's Avatar
FWIW check out the internal section for what cam and heads to look at
For the LTs Pacesetter, or Edelbrock are good low budget headers (around $400 coated) or if you want the high dollar ones Kooks are considered good headers, along with Dynatech (they're stainless steel, so they cost a good bit), Loudmouth with no cats is going to sound like a SBC with blown out glass packs, and it'll be LOUD (and a cam will only increase the sound), don't know if you want that or not, just letting you know
Check out www.ls1sounds.com for some videos/soundclips of various exhausts and cams
And welcome to Tech
Old 05-03-2006, 09:15 PM
fastfbody's Avatar
Default ...
im fully aware of what the slp loud mouth sounds like. my buddy has a 2005 mustang gt with long tubes h-pipe and a slp load mouth. i really like the way it sounds.
Old 05-03-2006, 09:29 PM
YoungGunLs1's Avatar
exhaust is going to sound different on a mustang than on a LS1 tho..just in case you didnt know that.
Congrats on the new car tho, and welcome to the site
Old 05-03-2006, 09:37 PM
fastfbody's Avatar
Default ...
no they wont
yes i know that my ls1 set up that way would sound differnt. but it gives my the ideal of what the slp does as far as sound .because alot of the time mustangs are loader then camaros.more then likely i will use a magna flow muffler or something .
Old 05-03-2006, 10:11 PM
stevespewterZ's Avatar
Welcome
Are you an auto or a six speed?
Pics!
Old 05-03-2006, 10:28 PM
Starz T/A 17's Avatar
Welcome to the site, and I have the LM exhaust and LOVE it just cant wait to get those LT's
Old 05-04-2006, 07:06 AM
fastfbody's Avatar
Originally Posted by stevespewterZ
Welcome
Pics!
Mystic Teal, a4, .323 gears, power everything, leather, 118k miles, all stock except airlid and cutout t-tops.
Old 05-04-2006, 07:46 AM
JstALs1's Avatar
I installed slp loudmouth when i first got my car and it sounded awsome but ever since i put in the cam and lt's with ory pipe it got soo loud. I didnt even want to drive the car cuz of the drone that it created even with the windows open i could barley stay in the car for any amount of time. So i took it off and put on SLP 2OTL and its quiet now. I suggest you get a different catback and if it is to quiet put a eletric cutout on in. But than again you might be able to with stand the noise. Just my .02 cents. Good luck with the car
Old 05-04-2006, 01:25 PM
BlueSix's Avatar
Since you have an auto a stall needs to be your first mod. Nothing smaller than a 3500 stall.
Stock rockers are fine, no need to replace them.
Go check out the internal section, and always use the search button before asking a question. You will find your answer much faster this way.
Old 05-04-2006, 02:49 PM
Ell Ess Won's Avatar
umm...I never seen a LS1 dyno lower than 290 bone stock, and thats a weak *** LS1, most will do 300-307
Old 05-04-2006, 02:51 PM
Tudds's Avatar
Welcome to Ls1tech
Old 05-04-2006, 06:57 PM
fastfbody's Avatar
Default really
because its rated for 305 at the flywheel.i did not really think it would make close to that at the wheels. it should put down higher then normal numbers because of where i live tennesse makes for crazy times at the track when its dry and cold.
Old 05-04-2006, 07:04 PM
J E T's Avatar
Originally Posted by fastfbody
no they wont
Yes, a LM on a 3v 4.6 will sound different than a 2v LS1. Simply put, two different engines, two different displacements and two different combustion/air flow will create a different sound.
Old 05-04-2006, 07:05 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
welcome.....SCENE ... not SEEN.
Old 05-04-2006, 07:07 PM
J E T's Avatar
GM rated the LS1 f-bodies at 305/320 because they didn't want it to be at or close to the Vette's ratings. The LS1 is a 350 hp engine, but RWP is around 300 hp. Typically, LS1's (Z28, Formula, T/A, SS, WS6, Firehawk, Corvette, GTO) will all dyno in between 290-320 stock, with the autos less and the manuals more.
Old 05-04-2006, 09:33 PM
fastfbody's Avatar
Default ...
it was a joke you goober
Old 05-05-2006, 12:10 AM
staringback05's Avatar
do a good check on that engine, a compression check, psi checks, etc....its got a good amount of miles and seeing whats not going good can give you an idea of what youd want to do first...
