Can't get second gear rubber?? WTF!
Old 06-15-2006, 06:00 PM
soontobeLS1's Avatar
Default Can't get second gear rubber?? WTF!
Well, went out the other day on back road. Hit first gear, spun RPM's up to about 5K, clutched er and then shifted to 2nd....No spin but the engine revved. Is that my clutch not grabbing hard enough???? My ol stang could do it no prob.
Just thought I would put that out there for some feedback.
Old 06-15-2006, 06:01 PM
DaGeneral's Avatar
I have never chirped second. Guess its the Falken Azenis
Old 06-15-2006, 06:04 PM
Iron Sights's Avatar
Well, what does your G-tech say?
So your are saying you engine revved (as in the car did not increase in speed), but your tires did not spin? Sounds like your clutch is slipping; put it in 6th at about 45mph and if your engine revs disproportionately with your speed then you have a slipping clutch, and should start looking for a new one.
Old 06-15-2006, 06:17 PM
kyles2000z's Avatar
^what he said
my stocker was like that, but the new stage 2 will chrip a healthy 3rd now
Old 06-15-2006, 06:20 PM
Mike02Z's Avatar
On my old Kuhmo Ecsta's I could get sideways going into second and chirp third. With my BFG KDW's I get a tiny chirp in second and none in third. The BFG's stick better. I also went from a P245 to a P275 so there is more tire on the road as well. I think you're probably worried for nothing.
Old 06-15-2006, 06:23 PM
NVR KNO's Avatar
yea, when i had my 245/40 series on the back, i could roast them in 1st, 2nd and halfway thru 3rd. now that i have 285/40 series in the back i can only burn thru 1st and chirp 2nd. i luv it, no traction problems!
Old 06-15-2006, 06:42 PM
98redM6's Avatar
It's probably the tires. I'm able to chirp second only when I have ASR activated. If I have ASR off, I don't chirp them, but I feel them spin.
Old 06-15-2006, 07:51 PM
My1st Truck's Avatar
Get a Mcleod Twin Disk...It will chirp them, it will also break your 10 bolt.
Old 06-15-2006, 11:00 PM
Domestic Demon's Avatar
My cas has Goodyear F1's at all 4 corners, with 285/40s in the back on 17's.
Like you said, no traction problems
Old 06-16-2006, 12:52 AM
That's exactly it...good for racing, she hooks and goes...but for fun???
And how can a tight clutch break your rear end when ya break the tires loose? It's the traction that causes the stress.
Glad I aint the only one who can't spin em in second....need more tourque I guess.
Old 06-16-2006, 01:13 AM
97BBlackZ's Avatar
It still puts a shock on the rear end.
Old 06-16-2006, 06:29 AM
777's Avatar
I don't think I have ever heard noise from my tires. The sumitumo's I have now nor the bfg drag radials. I know I'm spinning in 1st, 2nd, and 3rd because the back end is sliding around, however there is absolutly no noise. It's nice for cops, sort of; I guess it really doesn't matter because they could hear the engine. It kind of sucks though because people are like you really spun in 3rd gear? It's like did you not feel it move around.
Old 06-16-2006, 07:09 AM
Tech Resident
ChocoTaco369's Avatar
my tires suck at chirping too (even though i'm an A4). when i take off harder than normal, i can feel them spinning but i don't hear anything. it sounds like when you launch on gravel. the only time they chrip if it's a really smooth road, even from a standstill. otherwise they just sound like you're kicking up gravel. with an A4, 2.73's, 275's and Z06 rims, i couldn't chirp 2nd gear if my life depended on it awesome handling though
Old 06-16-2006, 12:28 PM
Ice Knight's Avatar
When my car was stock, it would really chirp/slide around into second, and make a little noise going into third if shifted hard, but now it doesn't make any noise anymore, it just does like 777 says....silently slides around...
I did get some new tire though, so that probably it...
Old 06-16-2006, 03:18 PM
Moderator
davered00ss's Avatar
I left a 4th gear strip about 100' long, and did not make a sound. you could feel the spin and see the marks (nitto 555r extreem drags) . Pluss I felt it get squirly.
Old 06-16-2006, 03:31 PM
SS4Luck's Avatar
haha i can roast first, get completely sideways into second and chirp/spin into third.... gotta love the gears and POS! Kuhmos
Old 06-16-2006, 03:50 PM
BADBLUE02's Avatar
Sounds like your clutch is about to go.
Old 06-16-2006, 04:07 PM
BriancWS6's Avatar
With my stock LS6 clutch and street tires it would get sideways when I hit 2nd hard, and chirp 3rd. Now with the TEXtralia and Nitto DRs it chirps 2nd hard, along with 3rd AND 4th! Your clutch is going for sure if the engine revs up like you described. Just because you don't physically "hear" a chirp doesn't mean it didn't break traction. Different tires and different road surfaces can make it where it doesn't make a sound, but you can feel it break loose.
Old 06-16-2006, 04:18 PM
blue01ta's Avatar
The main thing that decides if the tires make noise or leave a mark on the road is your tire compound.
Old 06-16-2006, 04:33 PM
mcG
mcG's Avatar
i'm on stock goodyears, can easily spin 1st, sideways into 2nd, and chirp 3rd if need be
Quick Reply: Can't get second gear rubber?? WTF!
