What thermostat to get?
If you are going to change the stat I would stick with stock or maybe a 180. Aluminum loses heat quickly (thermal efficiency) and you need some heat in the combustion chambers to keep things running optimally. I personally like 180 stats, but I like in hot, humid Louisiana.
Originally Posted by Ragingwolf51
IMO, put in the 160 degree thermostat, then set radiator fan #1 to 185, then set radiator fan #2 to 195. Done.
In all the time I've had this car, I have NEVER heard the 2nd fan kick on, even in 100 degree weather in traffic.
Both fans run simultaneously on my car, either on low or high speed, and you need an on/off temp for each setting. Set mine at 184/175 and 194/185. I can see my high speed fans kick on and off according to temp, even with the AC on in summer.
Originally Posted by fastest94v6
I bought my car with the 160 already in there....but the guy also had a hpp3. SO what i did is I tuned the fans for 195 so it warms up quicker....what should i do?
try and set fan #1 to 170 and fan #2 to 175
Thats what I would do.
-or-
If you wanna warm up quicker and be safe....go get a stock thermo
LS1Tech Administrator
Received 1,668 Likes
IMO, a stock to bolt-on LS1 shouldn't be run any colder than 190F for best overall results.
