knocking listen help
ok my car just started doing this about 3-4 months ago and i have no idea what to do if its a rod knock or piston slap. and if i get on it the oil pressure drops to 20 after i let off and will stay there till i get it over 2grand just wondering if anyone can help me out with this. here is the link to the video http://video.ls1tech.com/video/9153a...e60100388b.htm
take a stethiscope and check and see if thats coming from the head or not....its hard to tell on the video, but i mean it could be anything from a broken injector, cracked spring, or one of your plug wires might be off and it might be arching.....those are my best ideas
now when i put my hand over the filter i belive its one of the filters? it stops the ticking but the knocing and almost like grinding is still there heres pic i stole the pic from another site sorry
i also have another video of it but its like 6mins long and the ticking starts middle way throught of it, i will see if i can load it because i dont want to get rid of the car but the way its sounds when i start it, it makes my nerves jump and when its sitting in park or drive i can feel it like a up and down bounce going on.
here is what it sounds like without the tapping http://video.ls1tech.com/video/b96ee...e800a746bf.htm
how much oil pressure at 2 k this is just my thought .if it does this at operating temp its not piston slap.sounds like youve spun a bearing at first its not gonna affect oil pressure alot,but if you drive it alot it will ruin the rest of the bearings.second possibility
spun cam bearing,that ticking was lifters hands down,when a cam bearing goes down you will lose pressure to the valvetrain cusing the lifters to not pump up.have you checked the oil and filter for metal.i personaly wouldnt sell a car to somebody doing this.unless its to a dealer there mostly ripoffs anyway.
it only knocks or taps when i start it up in the moring once it gets warm theres no problems, but when its cold and i drive it when it goes to shift into second it sounds like it wants to blow the heads off, it raps like crazy over 3,000 rpm but when it gets warm it calms down. the oil stays at 45-60 psi when cold and will stay at 40-50 ish till it gets up over 180 degress closer to 210 the oil seems to drop to 25 ish and the longer you drive it the more it stays at 20 but in park or netural it will keep around 30-40 ish its a 98 a4 stock expect the for lid. with school and working part time looks like if i trade it will only be able to get into a 01 blazer
the oil is right on im running valvoline synthic 10w 30 throught it but it needs changed, i'm changing it tomorrow after work and im gonna check for metal shavings.
That's what she said...
Put on a K&N 2006 oil filter, it will boost your pressure a bit.
My oil pressure used to drop down that low untill I put in a ported/shimmed oil pump with my cam, but it never made that noise. Now it sits on 35-40psi when fully warmed up and hits 65+ under WOT.
Pinch of your AIR hoses while it's running and see if it stops, might be a check valve.
how much am i looking at if do deside to have a shop tear it apart and find out what the problem is? and to fix it, if it is say a bad bearing. forgot to say about a month before it started this i had got on it ( let it run out of 1st into sec and got out of it) and the check engine light came on and it ran like **** so autozone checked the code and said it was a 02 sensor thats bad but i never replaced it
sounds normal then
