Engine Temp
Old Apr 7, 2007 | 07:08 PM
BlueonBlack01-WS6's Avatar
Default Engine Temp
What is the normal operating Temperature for a 2001 LS1, seems like with the aluminum block it would obviously run hotter than the cast iron LT1. Mine usually runs strait up, or just a bit over. It never over heats but compared to my 98 GM vortec it runs a lot hotter. Whats the word?
Old Apr 7, 2007 | 07:09 PM
MikeD101898's Avatar
I think it's set at like 190? 185? Somewhere in there.
Old Apr 7, 2007 | 07:16 PM
RA4926's Avatar
my 01 ls1 runs straight up or a little past on an 80* day. engines that run hotter have a more complete burn.
Old Apr 7, 2007 | 07:17 PM
Intense's Avatar
190ish is right or then needle straight up
Old Apr 7, 2007 | 07:25 PM
aaron653's Avatar
correct me if i'm wrong...but i thought that the '98's were the only ones with accurate temp gauges
Old Apr 7, 2007 | 07:30 PM
jimmyblue's Avatar
Moderator
(1) Nothing obvious about aluminum vs iron. Aluminum
has better thermal conduction but it's also about
the head design, the water jacket and so on.
(2) Thermostat is a 194F setpoint, nominal 180 or so.
So do not pay for a "180F" aftermarket 'stat.
(3) Fan settings control engine temp, whenever there is
not enough cooling airflow (idle, street driving) and
the fan settings are stupid high: 226 for low and 234F
for high speed fan turnon. Hello, ping and coolant
smell.
(4) The temp gauge is a hoax meant to keep you amused,
not to provide realistic information (except the '98s).
If you can run your fans earlier you can maintain a 194F
operating temp consistently and the car will like that a lot
better than 220+. The temp gauge will still lie.
2001NBMZ28's Avatar
You're correct, the 99 and up gauges aren't accurate. With lower fan settings and a 160 mine stays just below 210.
Old Apr 7, 2007 | 07:37 PM
Thanks all, the 98 vortec i was refering to is in my Tahoe. My LS1 runs great, like i said it just seemed to run hotter than other cars that i've had, didn't figure anything was wrong just wanted to make sure it wasn't an anomalie.
Old Apr 7, 2007 | 10:09 PM
fccs's Avatar
yea I have a 98 and it usually stays at 160
