Intermittent starting problems
The pellet on the key (try a spare or check the resistance on it and see if it is in spec.Do a search here for VATS and you should find threads as to how you find out you key resistance specs with an Ohm meter)
Starter relay
Clutch position switch
Starter (like mentioned)
Just some ideas off the top of my head...Good luck.
Those of you that have had the same problem, when your car wouldnt start, what did you do to get it to start?
Good luck!
There is a good connection between the battery and the starter.
I'm at a freakin loss..........
Makes me want to say the hell with my jacked up back and get out in the shop and get my 70 done. At least that one I can work on.
Thanks for keeping us updated...
Of course,you have to take it back.You brought the car to them for a problem,you paid them money and it isn't fixed.I know it sounds like the start of an even bigger headache but,I would take it back.Dealers aren't known for being thorough.
I think this whole "hold it for 12 seconds" thing is a definate clue and the dealer just hasn't explored it very well.
Good luck...
