Is this true
Old Apr 17, 2007 | 08:45 PM
chuy10's Avatar
Default Is this true
Is it true that some 2001&2002 transam came with 1s6 engines I'v herd about ls6 block and intake but not engine ?
Old Apr 17, 2007 | 09:27 PM
Z28LS1camaroguy's Avatar
ive never heard of that, the LS6 block and intake are the only thing ive heard them coming with.
Old Apr 17, 2007 | 10:22 PM
ICEMAN 31's Avatar
this is news to me....I think whoever told you that might have meant intake
Old Apr 17, 2007 | 10:56 PM
Starz T/A 17's Avatar
yea, ALL Ls1's came with LS1 cams and such, but some of the 02's had the LS6 blocks, but the internals were still LS1's or at least thats what Ive read
Old Apr 18, 2007 | 05:30 AM
staringback05's Avatar
ls6 block...better windows, better cooling, weaker block
different manifold....
Old Apr 18, 2007 | 06:53 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Block and intake only. The rest of the engine was standard LS1 issue.
Old Apr 18, 2007 | 04:12 PM
LS1Formula01's Avatar
but that was only on about 10%(recieving the ls6 block) of f-bodies that came off the assembly lines for 01-02 model years, other than that all 01 and 02 f-bodies came with the ls6 intake standard
Old Apr 19, 2007 | 06:57 AM
signal12's Avatar
I heard some kind of urban legend similar to this post. Someone told me that GM took some of the Vette motors from the production line and put them in the 01-02' SS/TA. This was because of a shortage of LS1 motors. I don't have a clue either way.
Old Apr 19, 2007 | 07:05 AM
RPM WS6's Avatar
As stated above, there were a small amount of '01/'02 F-bodies that received the LS6 block (only the block, not the full engine), and all '01/'02 V8 F-bodies received the LS6 intake, but that is all.
The F-bodies never came with the LS6 cam or 243 (LS6) heads stock. Ever.
Old Apr 19, 2007 | 09:04 AM
777's Avatar
777
My 98 formula cam with an ls7, I don't know what you're talking about...
Old Apr 19, 2007 | 09:48 AM
signal12's Avatar
Is there an easy way to tell what block you have??
Old Apr 19, 2007 | 09:57 AM
Jon5212's Avatar
Glad I didn't buy an LS6 intake then!
Old Apr 19, 2007 | 12:01 PM
jbuerke142's Avatar
https://ls1tech.com/forums/showpost....86&postcount=8
Old Apr 19, 2007 | 01:07 PM
Blk97WS6's Avatar
Dammit, i thought i was the only one...
Old Apr 19, 2007 | 04:05 PM
signal12's Avatar
Great Info. Thanks
Old Apr 19, 2007 | 04:58 PM
02silvaZ's Avatar
'01-'02 F-BODY
10% LS6 block (not necessarily weaker, better bay-to-bay breathing at high rpms because the LS6 has a large portion of its power range in the upper rpm's, also contains more oil passages in the block for better oil flow)
LS6 intake manifold
LS6 clutch, pressure plate, flywheel - which also meant the updated hydraulics
( i have an LS6 block, no i am not special, but i like having it )
Old Apr 19, 2007 | 05:27 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
You too?!..... I thought I was the only one! .... Damit!!!.... So much for having a one of one factory freak!!!
Old Apr 19, 2007 | 05:29 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Cool
Mine came with a ls8.5
