Intake Manifold
Intake Manifold
I was looking for an intake manifold. Ive looked at a lot and found one that I have never heard of before. It is the BBK SSI intake manifold. It says it gives between 15 and 25hp and is 75mm, so it will fit on the stock throttle body. Its about $570. Sounds like a good deal. Do any of you know if this is any good?
Dont bother with the BBK,weildan etc... they are know to heat soak. Get a regular LS6 intake off an 01-02 car. http://www.dagostinoracing.com has one. I doubt its gonna give u 25hp increase, but deffinatley a noticible increase w/ a pp TB
LSX intakes are good, but IMO, the 78MM version is a waste of $$$, because you get nearly the same results with an LS6 intke. however the 90MM version is better, but only good on heavily modded H/C cars.otherswise, you wont see much of an improvement over the LS6.
in short, on a bolt on/mild cam car: LS6 intake.
wild cam/head car with full boltons: FAST 90/NW90
heatsoak is bullshit get the metal you will love it screw a plastic intake.i have the weiand love it no heatsoak issues made the car pull alot harder in the topend,and i dont have to worry about n20 backfires.i hated the look of my factory intake.half the people goin on about heatsoak havent even seen a metal intake let alone used one
Originally Posted by King Nothing
heat soak is crap, the only people who really see a differance if any is the guys who specifically 1/4. and don't go with FAST, just wasting your money if your not gonna run N20. send an LS6 from an 01-02 to TPIS and they'll port it for you to 90MM and you wont have to spend close to $900 on just an intake. good luck
thats crasy
thats the biggest load of **** ive heard in a while. how are you wasting your money if your not going nitrous? the FAST 90/90 combo will flow better than any ported LS6 intake anyone can come up with. otherwise, a **** ton of people wouldnt have it. theres a reason you dont see as many metal intakes on these cars as you do plastic. plastic is tried and true. ill never put a metal intake on my car. it gets hot enough as it is.
theres a thread in the dyno thread were a guy had a n20 backfire and blew a hole in his plastic intake
i 1/4
thats stupid look at the really fast cars they have sheet metal intakes.ive had both and im staying metal.**** a bunch of plastic junk.
so what, ive hotlapped my car before and actully ran faster. when you got a metal intake under the metal hood of an f-body, i can garuntee the BBK will be hotter than an LS6 intake.
i wouldnt bet on it
yes, sheet metal, that is completly different from the BBK/Wiend intakes that are in question here.
my car picked up alot of top end power from the weiand as well.im a nitrous person and have seen alot of plastic manifolds blown to bits.the fast has burst panels but look at the price.show me a video of a metal intake car on a dyno heatsoaking and losing power and ill agree with you till then your arguing is pointless.
Originally Posted by 98_Formula
this is stupid... just buy a ls6 intake and be done with it. cheap and does the job.
weiand better
to the op check this out if you havent alreadyhttps://ls1tech.com/forums/showpost....9&postcount=48
go metal if thats what you want dont listen to the heatsok bs.nobody has proved it.if you ever plan on sprayin stay away from composites unless it is a fast.ive got mustang buddies withepoxied intakes they will blow to bits.
