mass air flow sensor
okay my car would hesitate when i would press on the throttle and someone said to try and clean my mass air flow sensor. So i tried it and it worked for alittle while but now it is doing it again. Is my sensor messing up because it should get dirty again that quick. Any thoughts
i'm sure a hundred people are going to post in disagreeance with me but if you're having probs with it buy and Slp one
I did notice a good diff upgrading that,it doesnt flow more air but it tricks your comp into runnin leaner
i'd say it was more of a feelable diff then the lid for sure
everyone will say that the stock will be good to 500hp i've got two friends who are very smart when it comes to these cars and they both have them
slp MAF total waste of money...do a search...
take your car and have it scanned..last of all do you have a reusable airfilter such as a k&n?they are bad for the oil in them dirtying up the MAF mine does it often...
i do have a k&n air filter but i think i need to try and clean it again because when i drove it tonight it didn't do it so maybe if i clean it alittle more it will work fine
I slowly accelerating from a stop sign last night and all of a sudden my motor completely died on me and would crank over but then immediately die again so I waited about an hour for AAA and it fired up no problems when they go there so I drove it the 25 minutes home with no problems and when i got out and let it idle in the driveway it sputtered and died again. So I let it sit for about another hour and tried cranking it and it wouldn稚 even catch and more so I disconnect the MAF and it started up and ran just fine. I知 not sure if this is a dirty sensor or not but I知 wondering what would be the best thing to try and look into. I知 going to read the code when I get home from work.
Fuel filter should be changed every 10,000 miles. I'm not sue why they cant last longer than other cars but the owners manual suggests every 10k.. I agree with the CRC maf cleaner, its good stuff.
