need advice about installing headers.
Old May 24, 2007 | 09:46 PM
2002/ws6's Avatar
Default need advice about installing headers.
i planning to do it this sun/mon. I never installed headers, and a seem to hear a lot of people saying they have to put a couple blocks of wood under the jack to lift it higher. how safe is that? and if could see some pics it would be big a help.
Old May 24, 2007 | 10:05 PM
JKDZ28's Avatar
I just jacked mine up enough to be able to put the front wheels on ramps (seeing how you can't just drive up on them).
After that I would jack the rear wheels up and put them on ramps also. After getting all four wheels up on ramps I like to mount 2 sets of jackstands under the car. I guess I'm kind of a safety monkey. Oh well.
By getting the rear wheels up even with the front it gives plenty of room to do the install. I'm a big guy so if I can do headers with this little of room - you can too! Good luck!
Old May 24, 2007 | 11:45 PM
TXZ28LS1's Avatar
i just installed my pacesetters. one thing u can do to get your car up higher is to use spare tire. put your spare tire down, and put a jack on top of that and jack your car up..works wonders.
Old May 25, 2007 | 07:02 AM
teke184's Avatar
getting it high is the name of the game...makes the slide in from underneath much easier.
here is my write up
Old May 27, 2007 | 01:26 PM
LiT1_up's Avatar
You can not over do it when taking safety precautions while working under a car that is on jack stands.
Old May 27, 2007 | 03:02 PM
89Formulaws6's Avatar
find someone who has small arms, cause theres some tight spaces on the rear of the manifolds trying to undo those are a pita.
i'm glad i could use my school's lift for my header install
Old May 27, 2007 | 03:09 PM
ErikElvis's Avatar
I put the front up on ramps. Put a block of wood between the jack and K member and went as hight as she would go. Had no probs gettin the headers in.
Old May 27, 2007 | 03:24 PM
StreetLethal01's Avatar
Take off the coil packs and everything else is a breeze.
Old May 27, 2007 | 06:10 PM
davered00ss's Avatar
Moderator
Jack & jackstands work fine. I jack up front & rear. Driver side header goes in facing the front of the car and rotate it in. Passenger goes right up.
