Having to shift to much
Brian
It is possible (likely) you bent a valve too then. If it floated you probably hit a piston and bent the valve and the pushrod. I would guess the two valves that had bent pushrods also have bent valves. I'm sure this isn't what you wanted to hear.
Brian
This is my guess what is wrong. If someone else has any ideas!
You could have smoked the clutch and bent a valve. I can't really tell completely from what you are describing.
Brian
The backfire could be caused by loose rocker or something causing a valve not close. The revving, might be your clutch slipping badly.
Brian
I agree with what was said before. Get a compression test done to see if you bent any valves. If your losing a bunch of pressure on the two cylinders that had the bent PR's, then its most likely the valves.
Speed inc. is a sponsor on here. Send them a PM, im sure they can do a compression test for you, if you dont know how to do one yourself.
