Engine Replacement Question
Old Jul 4, 2007 | 11:39 PM
patricksd's Avatar
Default Engine Replacement Question
I was thinking about something today and wanted to run it by you guys. My car currently only has 55,000 miles on it - so I know I can get a lot more time out of it.
BUT, if I wanted to upgrade or change the motor before 100,000 miles, what would be the best route to go? Swap in a new LS1? An LS2? I'm sure getting another LS1 would be the easiest and least expensive way to go. But for an extra $1,200 one could upgrade to the LS2 and have 50 more HP.
My main goals would be still passing emissions and ease of installation - which is why I think simply putting in a new LS1 would be the way to go.
Old Jul 5, 2007 | 01:08 AM
staringback05's Avatar
better idea you havent thought of......keep your block....stroke it...a 383 set up is great and not near as expensive as replacing a motor....do that and H/C the motor youll beat a ls2 all day
Old Jul 5, 2007 | 09:33 AM
patricksd's Avatar
I thought about that. But how reliable is a 100,000 mile stock block that's been stroked?
Old Jul 5, 2007 | 09:46 AM
Thule's Avatar
well. when you install the stroker kit you basicly rebuild the cylinder block/internals, so its as reliable as it was well put to geather
Old Jul 5, 2007 | 09:52 AM
tylerdj's Avatar
Why wait until 100K miles to stroke it?
Old Jul 5, 2007 | 10:14 AM
dgvincent86's Avatar
Is your Z your daily driver?
Old Jul 5, 2007 | 02:35 PM
patricksd's Avatar
Well, I was thinking of getting the most out of this motor that I can before I drop a ton of money into it.
At 100K, I figured I'd buy a new motor (either a stock LS1 and stroke it) or a crate motor (LS2 or LS6).
Yes, its my daily driver - for now at least.
Old Jul 5, 2007 | 03:02 PM
Well by the time you hit 100k you'll have another daily driver I'm sure..........aluminum 427ci stroker LS7 ???
http://www.texas-speed.com/shop/item...d=693&catid=20
YES !
Old Jul 5, 2007 | 04:27 PM
a BLOCK....isnt going anywhere...how often do you hear about blocks breaking...some do but not ANYWHERE near the internals in them....a 100,000 mile block that gets cleaned up and stroked is like a brand new motor....
a forged stroked motor is very reliable and alot more feasible then just buying a crate motor
Old Jul 5, 2007 | 04:39 PM
patricksd's Avatar
That's good to know - and the reason I inquired about it. Roughly, what would it cost to stroke and forge a stock block? Also, is it still capable of passing emissions? Being in California, its something I have to think about.
Old Jul 5, 2007 | 04:44 PM
it will all be in the tune and highflow cats.....you can get kits from eagle or lunati between 2500$-4500$....
Old Jul 5, 2007 | 06:18 PM
patricksd's Avatar
Thats not bad at all. I remember reading a thread where a guy talked about the reliability issues with a stroker - but I think he had something bigger than a 383. I'm sure the larger you go, the more potential for issues exist.
Old Jul 6, 2007 | 03:26 AM
myk's Avatar
myk
Depending on the condition of the motor now and how you take care of it until 100k, you may still have quite a bit of life left in the engine even after 100k...
