car won't take any gas
This might be an involved fix. If you have not been messed with in any way. If its from an evap problem you will have to pull the tank to get at the evap stuff. There is a 1/2" vent on the top of the tank by the canister, if it gets clogged your car wont accept gas at all. Its like someone put a ball in the filler neck or something, it will just sit there and pool. This is my guess unless there is something im not thinking of. I pulled all my evap stuff off from the front to the back and put a line and a filter on that vent and ran it to my driver side wheel well. Boone
if you need to remove an reinstall the tank ill come do it for a thousand dollars cause thats how much of a pain in th *** neck arms shoulders leggs, knees it is. i would recommend anyone having to do this, spend the extra money and get the ac delco pump or better if thats what your gonna change, i once bought the after market from oriellys and i got what i paid for, i did the job about 4 times before everything worked right, also bringing bach the cheap **** and installling ac delco fuel pump
