Former Mustang, now LS1 owner has questions
Recently traded in my '96 Mustang for a '00 Z28. The Z is way faster, Mustang had cams, exhaust gears and tune and still can't hang so it had to go. Anyhow, I noticed that the Camaro has some engine noise at idle, kinda sounds like a knock, but oil pressure is good and steady and it goes away when you rev it off idle. Does it the same hot or cold. Car has 80K on the clock, and runs great. Any ideas or is this just a characteristic of the LS1's? It's a noticeable noise, you can hear it plainly when you are beside another car or are standing outside the car.
don't worry newbie....I've been into Turbo Buicks for a long time and recently picked up my LS1 car. I thought it had some bad valvetrain components, but its just a characteristic of the LS1 motor I guess. Mine goes away after she warms up....just step on the gas or turn the radio up!
It is hard to say without actually hearing it for myself. Not much you can do about it - just keep an eye on your oil level and pressure and run it! If it is a genuine problem, then the noise level will get noticeably worse with time.
no, it stays. It isn't a tick, it's a knock, a light one. goes away if you revv it above idle and don't hear it while driving, just at idle. You can hear it plainly about 10 feet and closer to the car. It's not a deep knock, just a light rap, rap, rap. Stays the same hot or cold. I also have a friend who has a Yukon and it does the same thing, only not quite as loud. Must be normal?? To me it sounds like a rod knock, but doesn't get louder if I run the RPM's up in neutral. so, guess i'll just drive it, if something is going to happen it should get worse with time.
Originally Posted by Snowman2K1
had to click on thread..i was also a former mustang owner now a ls1 owner..couldnt be prouder of my decision
Anyhow, back to the issue. The knock doesn't disappear, it's the same be hot or cold. still runs good though~
Originally Posted by 96gt4.6
lol, yea, i raced both cars against each other, as I still own the Mustang, and the Z beats it by around 4 every time. The Mustang has Comp Cams, Full exhaust from the headers back, gears and computer programming. It's an Auto also. The Z is bone stock cept for a K&N.
I have piston slap when cold, and it has gotten a little worse in 95k miles.
Also, sometimes when it's hot out and idling a lot in traffic, I can hear exactly what you describe. It has not gotten any worse and seem to lessen with a thick oil. I like to use a 10w-30/10w-40 mix. The newest SM oils out are on the thin side for their rating.
I wouldn't worry about the noise if the oil pressure is >35psi at warm idle.
I say piston slap. Check the sound on other F-body's, some piston slap is louder then others but it's normal. My piston slap is louder then normal, I took my car to the dealership several times thinking it was a bent rod or a loose value spring or broke spring. Change the oil see if it helps try Mobil 1 or royal purple.
i say its just valvetrain noise, mine does the same thing warm or cold its just there, cant really describe it, sounds like a mini sewing machine i guess. my car runs great like a bat outta hell! i wouldnt worry about it at all unless your car starts running like crap which i doubt it will. Just maintain it, and enjoy what a real enigine sounds and runs like JMO.
Yeah when I had my Cobra and Vette at the same time, I though something was wrong with the Vette. Damn LS1's have alot of valvetrain noise and they like oil especially with alot of high rpm driving.
