New Trans A & Questions
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
http://cgi.ebay.com/ebaymotors/1999-...QQcmdZViewItem
Ad is over,just using it for reference since I bought it.
Ok I just picked this trans am up today and have a few questions about what yall think of the deal and the problems.
Know Issues thus far:
Headlight Motor- Passenger side headlight goes up 3/4 of way then makes knocking sounds(5secs), vibrating and I must manually raise rest of way(not hitting nething), when it goes down it does then same thing after it goes all the way down.
Hi Beam-1 sealed beam out(problem get HID)
Back light for left side steering wheel controls - What kind of bulb(194?) pop the button off to get to it?
Transmission Grinding- Grinds if I put in first quickly at a stop, slide it slowly and its good. Grinds 4th ever now and then. Grinds others random/rarely. Could he slave cylinder not be disengaging the clutch all the way? Need new tranny? Used new rebuilt?
Driver Side speakers- Big door and 1 rear I think, used
12v appliance and cig lighter-Fuse?
TCS Mounting Plate loose- looks liek a clip of bottom broke off, used
Ash Tray Cap loose-one side is broke off may be able to pop back in, didnt try, used
Driver Side Side Mirror up/down asdjustability- the center part was loose until I "forced" back in(was liek a lil bar and a slot for it), was held on by corner screws, now dosent have up down
Tripodometer resets when car off- trip goes to 0 when the car is cut off
Brake Pulsation- new brakes/rotors
Dr. Side PL switch only lock, no unlock- um take apart and see if corroded?? used
When I say used just mean will probly buy that way to fix.
What do you all think of this deal?
Thanks,
Tommy
**Sorry about the thread title**
Some more I forgot:
No brake pedal rubber cover
Driver Side Reverse light cover cracked
Both Turn signal covers cracked
Headlights Dont shoot far, aimed low I assume
Thanks,
Tommy
Some more I forgot:
the head light issue is covered in a sticky somewhere, and the other things just seem like little stuff that you just have to figure out. Thats what I would do, little things one at a time.
Try draining the tranny and putting GM Syncromesh in it.
Sounds like the syncs may be going out but this stuff works wonders.
The headunit/speakers in our cars suck. Just trash it all and buy new.
Here's the sticky for the headlight's
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Are the brakes pulsating like it feels like the rotors are warped, or like ABS is going crazy?
Well if the syncromesh dosent work out I plan on doing a junkyard swap! Also had to order brass gear because 180 temp had been done before, but it comes up all the way.
