Re: Would it HURT?
I think what Chaz was asking about is trying to get more airflow across the radiator and area there. I just removed the front mount, and cut the foam. There is very little room for air movement once cut. I was looking for a way to do a new ram-air setup, something a lil more trick. But, looking at it, although the RA is out, it is a good way to get more fresh air onto the Trans cooler. Will it hurt anything, NO. As for "what if...." you get into an accident questions..Well its kinda like Mom telling you to make sure you have on clean underwear before you go out, so if you get into an accident and they rush you to the hospital at least you wont be "dirty"...Wrong...If I got in an accident as a teen with moms car, I know I would **** myself so that theory is a no go. Just likek if you remove the foam and hit something hard enought to cause damage, well.....you are driving a Camaro/Firebird so its not a tank and will most likely take on a great amount of front end damage. Hell its only a little urethane, styrofoam, plastic, rubber and I believe in there somewhere is a piece of metal or two.
