Throttle body hose won't fit, help!
I'm replacing my LS6 intake with the new 92mm FAST. My problem is the fact that I also have the KIFP air intake and the hose that goes between the T/B and MAF is not big enough for the Big Mouth T/B. Any suggestions?
You can try heating it up with a heat gun and streaching it over the throttle body if it is the stock bellows. If it is a smooth bellows or silicone bellows it may take a little more work.
i had a stock one i heated it with a heat gun and took a standard screw driver and a radiator pick and got it on the 92mm i called the company were i got it and they really had no suggestions so that just what i did
