Power Gain
Do all the free mods also. get some headers and a Y pipe. your in cali so I would go with the high flow cats.
then say by by to the 10 bolt
Not to be a smartass, but you should a little searching...I'll outline the basics for you. First, decide on what you want to do with the car. Then, work your suspension, you can make stupid power but if you can't put it to the ground...it's no good.
https://ls1tech.com/forums/suspension-brakes/819775-suspension-brake-tech-faq.html
Next, get the rear end out of the way. Take it out and sell the piece. You can put a 9", 12 bolt, Dana 60...even an older Ford 9" can work if you can fabricate and weld good.
https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
Fourthly, you might want to upgrade the transmission. Depending on what you have...you've got a shitload of options to go with. Built 4L80E's, TH-400, and Powerglide's are for the auto guys.
https://ls1tech.com/forums/automatic-transmission/728728-commonly-asked-stall-transmission-related-questions.html
Personally, all that stall **** ***** with my head. Plus, auto's are about as fun as a 16 year old virgin in bed...if you think you can go stick then go with that. The 6-speed in our cars is called the T-56. You can get them built, or buy an upgraded tranny. G-Force makes some pretty good ones....also you'll need a new clutch. I recommend Mcleod...they make some stout ****.
https://ls1tech.com/forums/manual-transmission/510788-manual-transmission-faq-look-here-first.html
THEN, you work on the motor. You can from mild to WILDER than hell in a second. Everything from bolt on's to the internal motor. Then, you can get into aftermarket blocks...since I wouldn't push the stock bottom end much past 600 RWHP. Tons of options here...just look around....
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/361959-so-you-wanna-fast.html
https://ls1tech.com/forums/generation-iii-external-engine/520845-mod-guide-induction-exhaust-please-read-before-posting.html
https://ls1tech.com/forums/generation-iii-internal-engine/772576-got-cam-heads-rocker-machining-questions-about-ls1-ls2-ls6-read-me-first.html
Then, you get into FI (Supercharger/Turbocharger) and/or Nitrous set-ups. This get's a little more complicated and you should really know what you're doing before you start walking down this path.
https://ls1tech.com/forums/forced-induction/567592-real-price-forced-induction.html
https://ls1tech.com/forums/forced-induction/208864-turbo-faq.html
http://www.forcedinductions.com/help.htm
While doing this...you should either learn how to tune the car or become real good friends with somebody that does know how to. Tuning is where the money is at....
Always remember though, a car works like a sports team. It's only as good as it's weakest link. If the driver can't drive...a 1000 RWHP car isn't ****, so don't forget the driver mod.
Just my humble opinion.
Cheers.
have fun
http://www.strangeengineering.net/ne...earendAD1.html
