? about c5 z06
? about c5 z06
it produces 405hp to fly wheel...now couldnt you put the ls6 intake, z06 cam, and the heads of of this motor and put them on a 2000 ls1 and be putting down the same power and safefully doing so... please correct me if i am wrong...just a thought....
your wanting to turn a ls1 into a ls6?
you might have some freak car. but a z06, which is making more than your 353/361 AND is almost 500 lbs lighter is not going to loose to yours. driver, maybe. but the numbers dont add up. everyone knows what it takes for a fbody with a good driver to hang with a z with a good driver. been questioned to many times.
I've see Z's turn out as high as 360+ stock. They claim it's rated at 425 crank, again underrated.
As for weight, Im not at stock weight. And how the hell does a 3115lb (without driver) car weigh 500lbs less than a 3400lb car?
Im sure now with the 17rwhp/16rwtq and the better tires I have I could squeeze a 13.3 out of it with out problems. Im not taking anything away from any Z, Im just saying if your going to try and copy one, make it worth it. Do a larger cam, better heads and as for the intake the LS6 is just fine but the FAST will out perform it.
